marc10k
Timer1 is 20% off on PIC18F8722 |
Posted: Mon Sep 14, 2009 12:52 am |
Hello
I am using Timer1 to count my operating hours of the device and store the value every 15 min into the EEPROM. After 71 hours of operating the counter shows me only 57 hours. This is a difference of 20% to the expected value.
I use to following to setup the counter. The clock is 32 MHz and an overflow will occur every 65,536 ms.
Code: | setup_timer_1(T1_INTERNAL|T1_DIV_BY_8); // Timer 1 enabled, int every 65ms |
The fuse is
Later on in my code i enable the counter with
Code: | enable_interrupts(int_TIMER1); |
The ISR for Timer1
#int_TIMER1
void TIMER1_isr()
int temp, i = 0;
int32 zero = 0; // used for writing a 0 into EEPROM
Power_on_counter++; // increment the power on counter
if (Power_on_counter >= 13733) // 15 minutes are gone by
if (GOperating_min >= 0x04) // 60min are gone by
Internal_EEPROM(0, Addr_Operating_time, GOperating_time, 32); // read hours
GOperating_time++; // add one hour
Internal_EEPROM(1, Addr_Operating_time, GOperating_time, 32); // write hours
Internal_EEPROM(1, Addr_Operating_min, zero, 8); // write minutes = 0
GOperating_min = 0x00; // clear the min counter
for (i = 0; i < 4; i++) // store the time in ring buffer
ring_buf[114+i] = *((int8 *)&GOperating_time+i); // storing each byte
else // copy data back to global variable
GOperating_min++;
Internal_EEPROM(1, Addr_Operating_min, GOperating_min, 8);
Power_on_counter = 0; // clear the counter
An external Interrupt occurs 833 times per second Int RBA, RBA2, TBE and TBE2 are also used. The serial speed is 19k2 and 115k2 for the two serial lines.
The ISR for the external interrupt has quite some code in it and cannot be changed. But this takes not longer than 65ms. So in my opinion it should be no problem even if the Timer1 Int occurs while the prgoramm another ISR executes. After exiting the ISR the Timer1 ISR should be executed, right? As the Timer1 rolls over automatically at 2^16 counts and starts at the beginning nothing should be lost.
Is there something I have missed or a general problem?
Thanks.
Marcus
The code for Internal_EEPROM(): Code: | /******************************************************************************
* Access to the internal EEPROM of the Microcontroller *
* R_W -> 0..read, 1..write *
* Base_Address-> internal EEPROM address *
* Data -> data to read from/write into internal EEPROM *
* Length -> how long is variable ( 8..8 bit, 16..16 bit, *
* 24..24 bit, 32..32 bit) *
* Returns -> 1..everything OK, 0..EEPROM write failed *
#inline
int1 Internal_EEPROM(int1 R_W, int Base_Address ,int32& Data, int Length)
int j, i, loop_end;
int32 ReRead;
loop_end = Length/8; // determine how many bytes need to be read/written
switch (R_W)
case 0: // Read from internal EEPROM
Data = 0x00;
for(i=0; i < loop_end; i++)
*(((int8 *)&Data)+loop_end-i-1) = Read_EEPROM(Base_Address + i);
return(OK);
case 1: // Write to internal EEPROM
for (j = 0; j < INT_ROM_RETRY; j++) // write until error exceeds threshold
ReRead = 0x00;
for(i=1; i <= loop_end; i++)
Write_EEPROM(Base_Address+i-1, *((int8 *)&Data + loop_end - i)); // write data to the EEPROM
*(&(int8 *)ReRead+loop_end-i-1) = Read_EEPROM(Base_Address + i); // read written data
if (ReRead != Data) { continue; } else return(OK);
// Error_Report(Error_Int_EEPROM);
return(FAILURE);
} break;
Posted: Mon Sep 14, 2009 12:58 am |
Quote: | The clock is 32 MHz
The fuse is #FUSES LPT1OSC |
The Timer1 oscillator doesn't run that fast. What is the frequency
of the crystal on the T1OSC pins ? Is it 32.768 KHz ? (watch crystal)
Or some other frequency ? |
marc10k
Posted: Mon Sep 14, 2009 1:41 am |
I am using only the 32 MHz system clock. T1OSC (T1OSO and T1OSI Pins) are used as a output Pins. |
Posted: Mon Sep 14, 2009 4:24 am |
Please consider, that the processor executes your code rather than guessing your intention.
GOperating_min counts 0->1, 1->2, 2->3, 3->4, 4->0. How many states do you see?
71*4/5 = (about) 57 |
marc10k
Posted: Mon Sep 14, 2009 6:16 am |
@FvM
Thank you for your help. After I changed to 4 states it works well. I must have been blind to see that. |
bkamen
Posted: Mon Sep 14, 2009 11:15 am |
It happens to all of us...
External review is one of the best methods to find/fix problems.
Also, make sure to comment the crap out of your code.
When I'm doing something new, I write (in text comments) the flow of what I want right in the file...
Then I file in the code of how it should work (and sometimes alternative methods for doing it and why they might be better)....
You'd be surprised how writing that stuff out helps not only YOU but the NEXT GUY who has to work on your code.
I used to write code for a test fixture system made by this one company. Their programming language was horrible..
One of my co-workers would work with the fixture and always complain that my testing procedures were awkward and I would always tell him "that's the way the language works... I wish it was different."
I quit that company and was back visiting one day and that same co-worker said to me, "I had to jump into some of your code to update it... and I owe you an apology." He went on to say how horrid the language was and how the obscene amounts of comments by me saved him a lot of time and hassle.
So it DOES help!
