PWM frequency incorrect
cell514
PostPosted: Sat Sep 05, 2009 11:53 pm     Reply with quote
I read the following thread and used the formula shown;
http://www.ccsinfo.com/forum/viewtopic.php?t=17993
But still my coding doesn't work. I'm using a 20mhz crystal and I want to obtain a 5khz pwm output from a 16f877a. For some reasons, I get a frequency of 250hz (T=4ms) (simulated using software).
I also tried to obtain other frequency (using calculation first) and all were incorrect... any help is very welcome.
Here it goes:
#include "16F877A.h"
#use delay(clock = 20000000) //20MHZ crystal
main()
//output_low(PIN_C1);   // Set CCP2 output low
setup_ccp1(CCP_PWM);  // Configure CCP1 as a PWM
setup_timer_2(T2_DIV_BY_4, 249, 1);  // 5Khz frequency according to formula..
set_pwm2_duty(124);                    // 50% duty cycle on pin C1
while(1);  // Prevent PIC from going to sleep  (Important !)
//Gives 250hz frequency...
PostPosted: Sun Sep 06, 2009 2:14 am     Reply with quote
What software?.....
Your frequency looks right.
I'd suggest your software thinks you are running on a 1MHz clock. Remember the simulator itself also needs to be told the processor frequency.
cell514
PostPosted: Mon Sep 07, 2009 8:32 pm     Reply with quote
You were right thanks, it was a software problem; frequency is ok now (I were using ISIS 7 software).
However, now the duty cycle is incorrect. Pwm high value is (and stays at) 50us for T=200us. Any ideas?
FvM
PostPosted: Mon Sep 07, 2009 11:12 pm     Reply with quote
How about consulting the CCS C manual regarding set_pwm2_duty()? It knows about 10 bit pwm resolution...
cell514
PostPosted: Tue Sep 08, 2009 8:17 pm     Reply with quote
hmm.. I tried already and it doesn't work. Also tried the L (typecast) and didn't work either...
Also there's more:
Which is the right code when using CCP1 (pin C2) on a 16f877a:
set_pwm1_duty()
or
set_pwm2_duty()
Because I get a signal for the second one only and all examples uses the first one... This is confusing.
Also, I'm wondering if there are (more) limitation regarding PWM when clocked at 20mhz?
PostPosted: Tue Sep 08, 2009 8:21 pm     Reply with quote
1. Post your compiler version. It's a 4-digit number in this format x.xxx
and it's given at the top of the .LST file, which is in your project directory.
2. Are you running real hardware or a simulator such as Proteus or Oshonsoft ?
PostPosted: Wed Sep 09, 2009 2:36 am     Reply with quote
Perhaps note that you are setting up ccp1, then setting the pulse width on ccp2....
cell514
PostPosted: Wed Sep 09, 2009 8:12 pm     Reply with quote
Compiler version: 4.088
I'm running a simulator; Proteus
I know... okay, tomorrow I'm programming a real Pic and I'll check the signal with an oscilloscope and post back the results. Rolling Eyes
languer
PostPosted: Thu Sep 10, 2009 12:30 am     Reply with quote
Are you using PWM1 or PWM2. Looks like you are combining both in your code.
Try:
set_pwm1_duty(500L);   // 5kHz / 50% duty cycle
or:
setup_ccp2(CCP_PWM);   // Configure CCP2 as a PWM
set_pwm2_duty(500L);   // 5kHz / 50% duty cycle
