how to fgets()
Goto page 1, 2  Next
dbsjro
how to fgets()
PostPosted: Sun Sep 06, 2009 4:56 am     Reply with quote
Hello everyone!
Can someone provide any help?
I am using pic16f628 and can't make fgets() work.
Any example would be great.
thnx a lot Wink
PostPosted: Sun Sep 06, 2009 1:45 pm     Reply with quote
This thread has a discussion of fgets() and the get_string() function.
See my sample program for get_string():
http://www.ccsinfo.com/forum/viewtopic.php?t=36796
The #use rs232() statement requires that specific pin numbers
must be used for the 16F628 (or 16F628A). These pins are different
than the 16F877. See this post for an example:
http://www.ccsinfo.com/forum/viewtopic.php?t=37869&start=3
dbsjro
PostPosted: Mon Sep 07, 2009 11:37 am     Reply with quote
Ok first of all thnx for the reply
I am able to sent/read characters but I had no luck with strings.
I've read these threads but considering I am a newbie I'm kinda lost..
Is there any simple code?(or not that simple but one that is already working)
Arrow THNX Exclamation
PostPosted: Mon Sep 07, 2009 6:27 pm     Reply with quote
Here's a sample program for get_string(). Just type in a short string
such as "Hello" (without the quotes) and this program will send it back
to the terminal window:
http://www.ccsinfo.com/forum/viewtopic.php?t=36796&start=7
dbsjro
PostPosted: Wed Sep 09, 2009 11:28 am     Reply with quote
If only i knew as much as you i would be 1000000... times happier Laughing
This seems to work but i have a difficult one now
I wanna sent a string from my PC (can hyperterminal send strings?If not how can i?) and when it is the one i want, lets say "1234",
output_bit(PIN_B0)
output_bit(PIN_B1)
Man i hope i wont bother you again
Wink
PostPosted: Wed Sep 09, 2009 1:05 pm     Reply with quote
Just type in some characters and then press the Enter key. The fgets()
function will detect the Enter key as the end of the input string.
It's better to use the get_string() function, instead of fgets(), because
get_string() allows you to set a limit on the input string size. With fgets()
you can easily type in more characters than the size of your input array.
Then you will overwrite RAM locations beyond the end of the array and
probably cause the program to crash. Example for get_string():
http://www.ccsinfo.com/forum/viewtopic.php?t=17563&start=6
dbsjro
PostPosted: Wed Sep 09, 2009 1:27 pm     Reply with quote
Why it prints only " You are mistaken "
Can i fix it?
#include <16F628.h>
#fuses XT,NOWDT,NOPUT,NOPROTECT,NOLVP,BROWNOUT,HS
#use delay(clock=4000000,RESTART_WDT)
#use rs232(baud=9600, xmit=PIN_B2, rcv=PIN_B1, parity = N, bits = 8,STOP=1)
#include <input.c>
#include <stdlib.h>
{ while(true){
char temp[5];
printf("Enter string: ");
get_string(temp, sizeof(temp));
printf("\n\rReceived: %s \n\r", temp);  //please explain this line
    if ( temp == "0609")
         printf(" You found it ");
      else {printf(" You are mistaken ");}
PostPosted: Wed Sep 09, 2009 1:44 pm     Reply with quote
You can't compare the buffer contents to a literal string in this way.
There are special functions to do this. One of them is called strcmp().
Another useful one is strncmp().
Google for tutorials:
strcmp in C
or
strncmp in C
or
string handling functions in C
dbsjro
PostPosted: Wed Sep 09, 2009 2:07 pm     Reply with quote
Shocked Shocked Shocked You are amazing!!!!!
I won't trouble you....for the moment at least Wink
dbsjro
PostPosted: Sat Sep 12, 2009 8:27 am     Reply with quote
More questions Sad
Can i do the same without having to press Enter?
I am sending data but matlab dosen't support keystroke, meaning the program stucks waiting for Enter...
PostPosted: Sat Sep 12, 2009 11:34 am     Reply with quote
Can Matlab send some other character to mark the end of the string ?
(Some character that you can choose). If so, then you can re-write
the get_string() function to look for that character instead of a carriage
return.
If not, then does Matlab send a constant number of digits ? If so, then
you can count the number of digits to tell when the string has been
received.
dbsjro
PostPosted: Sat Sep 12, 2009 12:29 pm     Reply with quote
If i get what you are saying right then it's yes to both
If it is possible give me examples or anything for both
Thnx
PostPosted: Sat Sep 12, 2009 12:37 pm     Reply with quote
It's better if you try to code it and debug it. If you still can't make it
work, then ask for help.
dbsjro
PostPosted: Sat Sep 12, 2009 12:39 pm     Reply with quote
i m lost again Shocked
Code and debug what?
PostPosted: Sat Sep 12, 2009 12:52 pm     Reply with quote
I'm referring to your request for code, here:
The purpose of this forum is not to write code for you. We may seem
to do that a lot, but we really shouldn't. If you don't learn how to write
code by yourself, you will forever dependent on some forum to do it
for you. It's far better to be able to do it yourself.
Goto page 1, 2  Next
Page 1 of 2
