rs232 putc freeze
tamagee
rs232 putc freeze
PostPosted: Fri Sep 04, 2009 6:04 pm     Reply with quote
Problem with rs232 output on 18F26J50. Code freezes at putc command. Same with printf. With serial calls commented out, program runs fine.
#include <18f26j50.h>
//#device icd=true
#fuses INTRC_IO,NOWDT,NOPROTECT,
#use delay(clock=8M,internal)
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7,stream=COM_A, ERRORS,BRGH1OK)
#include <input.c>
#include <stdlib.h>
#include <stdio.h>
#INT_RDA
void serial_isr()
#int_default
default_isr() {
void main (void)
   disable_interrupts(GLOBAL);
// configure USART
set_tris_c(10000000);
while(1) {
   putc('U');
   //printf("U");
   output_high(PIN_A1);
   output_low(PIN_A1);
tamagee
PostPosted: Fri Sep 04, 2009 9:26 pm     Reply with quote
From the asm listing, Getting an infinite loop at lines 154/156
4: #use rs232(BAUD=19200, parity=N, bits=8,uart1, ERRORS,BRGH1OK)
00A2 AA9E BTFSS 0xf9e, 0x5, ACCESS
00A4 D7FE BRA 0xa2
00A6 CFAB MOVFF 0xfab, 0x18
00AA CFAE MOVFF 0xfae, 0x1
00AE A218 BTFSS 0x18, 0x1, ACCESS
00B0 D002 BRA 0xb6
00B2 98AB BCF 0xfab, 0x4, ACCESS
00B4 88AB BSF 0xfab, 0x4, ACCESS
00B6 EF7E GOTO 0xfc
0154 A89E BTFSS 0xf9e, 0x4, ACCESS
0156 D7FE BRA 0x154
0158 6EAD MOVWF 0xfad, ACCESS
015A EFD5 GOTO 0x1aa
PostPosted: Sat Sep 05, 2009 1:08 am     Reply with quote
You're setting the TRIS to 10 million. You don't actually need to set TRIS.
But if you do, and you if use a binary number, you need to prefix it with
"0b".
But to test your problem, I made a little test program:
#include <18F26J50.h>
#fuses INTRC_IO, NOWDT
int8 c;
   c = getc();
   putc(c);
I compiled it with vs. 4.098 and found a large number of problems
with the UART1 code, as shown below. I don't have vs. 4.099 to test
at the moment. I can test it on Sunday, maybe. But if you have 4.098,
your serial code just won't work. The generated ASM code is too buggy.
The basic problem is that CCS is using a register map that is suitable
for the 18F452, etc., nut these "J-series" PICs have a different register
map. Maybe they fixed it in 4.099. I'll check it later in the weekend.
.... #use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, ERRORS)
// getc():
0004:  BTFSS  F9E.5   // PIR1.RC1IF
0006:  BRA    0004
0008:  MOVFF  FAB,05  // SPBRG2 *** BUG: Wrong register
000C:  MOVFF  FAE,01  // TXREG1 *** BUG: Wrong register
0010:  BTFSS  05.1
0012:  BRA    0018
0014:  BCF    FAB.4   // SPBRG2 *** BUG: Wrong register
0016:  BSF    FAB.4   // SPBRG2 *** BUG: Wrong register
0018:  GOTO   0054 (RETURN)
// putc():
001C:  BTFSS  F9E.4   // PIR1.TX1IF
001E:  BRA    001C
0020:  MOVWF  FAD     // TXSTA1
0022:  GOTO   005C (RETURN)
... void main()
0026:  CLRF   FF8
0028:  BCF    FD0.7
002A:  CLRF   FEA
002C:  CLRF   FE9
002E:  CLRF   F9B  // OSCTUNE
0030:  MOVLW  70
0032:  MOVWF  FD3  // OSCCON
0034:  MOVF   FD3,W
0036:  BCF    FB8.3  // ECC2PAS *** Bug:  Not needed
0038:  MOVLW  0C
003A:  MOVWF  FAF  // RCREG1 *** Bug:  Not needed
003C:  MOVLW  A2
003E:  MOVWF  FAC  // RCSTA1
0040:  MOVLW  90
0042:  MOVWF  FAB  // SPBRG2 *** Bug: Wrong register
0044:  MOVF   FC1,W  // ADCON1
0046:  ANDLW  C0
0048:  IORLW  0F
004A:  MOVWF  FC1
004C:  MOVLW  07
004E:  MOVWF  FB4  // CCP2CON *** Bug: Wrong register
0050:  CLRF   05
.................... int8 c;
.................... while(1)
....................    c = getc();
0052:  BRA    0004
0054:  MOVFF  01,06
....................    putc(c);
0058:  MOVF   06,W
005A:  BRA    001C
005C:  BRA    0052
PostPosted: Sun Sep 06, 2009 3:12 pm     Reply with quote
Vs. 4.099 has the same bugs for the 18F26J50 and 18F46J50.
I just sent CCS a detailed email on it. Here's part of it:
Here is the annotated .LST file, showing all the bugs in the register addresses.
// getc():
0006: BRA 0004
0008: MOVFF FAB,05 // SPBRG2 *** Bug: Should be RCSTA1 at register address 0xFAC
000C: MOVFF FAE,01 // TXREG1 *** Bug: Should be RCREG1 at register address 0xFAF
0010: BTFSS 05.1
0012: BRA 0018
0014: BCF FAB.4 // SPBRG2 *** Bug: Should be RCSTA1 at register address 0xFAC
0016: BSF FAB.4 // SPBRG2 *** Bug: Should be RCSTA1 at register address 0xFAC
// putc():
001E: BRA 001C
0020: MOVWF FAD // TXSTA1 *** Bug: Should be TXREG1 at register address 0xFAE
... void main()
0026: CLRF FF8
0028: BCF FD0.7
002A: CLRF FEA
002C: CLRF FE9
0030: MOVLW 70
0034: MOVF FD3,W
0036: BCF FB8.3 // ECC2PAS *** Bug: Should be BAUDCON1 register address at 0xF7E
0038: MOVLW 0C
003A: MOVWF FAF // RCREG1 *** Bug: Should be SPBRG1 register address at 0xFB0
003C: MOVLW A2
003E: MOVWF FAC // RCSTA1 *** Bug: Should be TXSTA1 register address at 0xFAD
0040: MOVLW 90
0042: MOVWF FAB // SPBRG2 *** Bug: Should be RCSTA1 register address at 0xFAC
0046: ANDLW C0
0048: IORLW 0F
004A: MOVWF FC1
004C: MOVLW 07
004E: MOVWF FB4 // CCP2CON *** Bug: Should be CMCON register address at 0xFD2
// But, additional bug: The comparator registers in the 18F46J50-series
// don't have the same bit assignments as in the 18F4520. So it's not
// valid to write 0x07 to it. This all has to be cleaned up.
0050: CLRF 05
0052: BRA 0004
0054: MOVFF 01,06
0058: MOVF 06,W
005A: BRA 001C
005C: BRA 0052
// This test program is just concerning the UART registers. It's possible
// that all the rest of the registers are screwed up as well.
PostPosted: Wed Jan 13, 2010 2:07 pm     Reply with quote
Here is the generated code for vs. 4.104. They fixed almost all of it. I've
added comments to lines that were previously buggy, but are now fixed.
0004:  BTFSS  F9E.5
0006:  BRA    0004
0008:  MOVFF  FAC,04   // RXSTA1 *** Fixed
000C:  MOVFF  FAF,01   // RCREG1 *** Fixed
0010:  BTFSS  04.1
0012:  BRA    0018
0014:  BCF    FAC.4    // RCSTA1.CREN *** Fixed
0016:  BSF    FAC.4    // RCSTA1.CREN *** Fixed
0018:  GOTO   005C (RETURN)
001C:  BTFSS  F9E.4
001E:  BRA    001C
0020:  MOVWF  FAE
0022:  GOTO   0064 (RETURN)
0026:  CLRF   FF8
0028:  BCF    FD0.7
002A:  CLRF   FEA
002C:  CLRF   FE9
002E:  CLRF   F9B
0030:  MOVLW  70
0032:  MOVWF  FD3
0034:  MOVF   FD3,W
0036:  BCF    F7E.3  // BAUDCON.BRG16  *** Fixed
0038:  MOVLW  0C
003A:  MOVWF  FB0  // SPBRG1  *** Fixed
003C:  MOVLW  A2
003E:  MOVWF  FAD  // TXSTA1  *** Fixed
0040:  MOVLW  90
0042:  MOVWF  FAC  // RXSTA1  *** Fixed
0044:  MOVLW  FF
0046:  MOVLB  F
0048:  MOVWF  x48  // ANCON0 = all digital  *** Fixed
004A:  BCF    FC2.6  // ADCON0.VCFG0  *** Fixed
004C:  BCF    FC2.7  // ADCON0.VCFG1  *** Fixed
004E:  MOVLW  FF
0050:  MOVWF  x49   // ANCON1 = all digital  *** Mostly Fixed
// There is a slight bug in the section above.  It turns on the
// Band Gap voltage generator when it's not needed.  They
// really should have moved 0x1F into ANCON1. But it's not
// that important.  If you want to turn it off, then use a #bit
// statement to define the address of the bit, above main():
// #bit VBGEN = 0xF49.7
//  Then write a 0 to that bit in main():
// VBGEN = 0;
0052:  MOVLW  07
0054:  MOVWF  FB4  // CCP2CON  *** Still a Bug
// I believe their goal was to turn off the two comparators, but
// the CM1CON and CM2CON registers are at 0xFD2 and 0xFD1.
// However, the comparators are turned off by default upon
// power-on reset of the PIC anyway.
// Writing 0x07 to CCP2CON puts the CCP2 module in this mode:
// "Capture mode, every 16th rising edge".   To turn it off, just add
// this line to the start of main():   setup_ccp2(CCP_OFF);
0056:  CLRF   04
Just now, I emailed CCS support about the items listed above.
