float to integer conversion
asimraufawan
View user's profile Send private message Send e-mail Yahoo Messenger MSN Messenger
PostPosted: Fri Sep 04, 2009 5:46 am     Reply with quote
how to convert the floating value into integer or long integer.
PostPosted: Fri Sep 04, 2009 6:59 am     Reply with quote
C does this automatically. Just pass a value from a float variable to a int variable, and the int variable receives the integer part of the float. A search here will find a lot of examples, and also if you search on the keyword 'cast', you will find how to force the conversion at different points in an equation.
