		| Author | Message |
		| sjharris
				| GLCD - S6B1713 chip |
				|  Posted: Tue Aug 11, 2009 9:30 am |   |
				| Hello all,
 I have recently managed to complete a 4 x20 line LCD project and I am now wanting to move onto a more challenging Graphical LCD project.  I will be using a Bolymin 80x32 LCD
 http://www.craftdata.co.uk/pdf/Bolymin_Graphic_LCD_2009.pdf (BO8032A, on second page)
 It has this controller on board
 http://www.crystalfontz.com/controllers/DS_S6B1713_R42.pdf
 I have not done any GLCD before and would appreciate any help at all in getting the device working.  Also what librarys can control this device (I had to change the LCD library to work with the 4x20 screen, so I can only assume that there will be some modification to get this working).
 Thanks in advance
 Kind Regards
 SH
		| Guest
				|  Posted: Tue Aug 11, 2009 6:01 pm |   |
				| Hi,
 A quick Google search (you tried that , correct?) finds that your controller is compatible with the KS0713 controller which does have a driver supplied with the compiler by CCS.
 That should get you going!
 Charlie
		| PCM programmer
		| sjharris
				|  Posted: Wed Aug 12, 2009 3:30 am |   |
				| Thanks for info.  When I programmed the 16x4 line LCD I had to change the provided LCD code to enable the device to run in '4 line mode'.  This was not a simple task to test.  Is there likely to be anything that needs to be done to change from one controller, the KS0713 for example, to mine the S6B1713?
 Also does anyone know how to send pictures to the screen?
 Thanks in advance
 Regards
 SH
		| PCM programmer
		| sjharris
				|  Posted: Thu Aug 13, 2009 5:05 am |   |
				| Thanks for reply.
 SH
		| sjharris
				|  Posted: Thu Sep 03, 2009 8:53 am |   |
				| Having set this up on a PCB, connections as shown:-
  	  | Code: |  	  | PIC______LCD
 D1_______RS
 D2_______SID
 D3_______SCLK
 D4_______RST
 D5_______CS
 As per connections on http://www.techdesign.be/projects/042/042.htm and programmed PIC (18F452) up with the code.
 When I power the PIC up I only get a black screen.  (All the pixels are black).
 If I repeatedly power / shut down the PIC, occasionally I will get part of the original strings for split second, then the screen goes black.  It is like the text is printed then the screen fills with black almost immediately.
 The screen I am using is this one http://www.craftdata.co.uk/pdf/Bolymin_Graphic_LCD_2009.pdf and has this controller http://www.crystalfontz.com/controllers/DS_S6B1713_R42.pdf.
 The screen is 80x32 and not 128x64 as in the website.
 I do not know what to do as I have not done a GLCD before, I have checked the initiation strings and all seem to be the same (the controllers are compatible).
 Any help will be most appreciated.
 TIA
 SH
		| PCM programmer
		| sjharris
				|  Posted: Mon Sep 07, 2009 3:23 am |   |
				| Ahah, I will try this today.  Thanks a lot, lots of info on second page!!
		| sjharris
				|  Posted: Fri Sep 11, 2009 2:51 am |   |
				| Agh, Something is not working now.  The GLCD does not respond anymore!!  I cannot even get the black screen up!!
 I must have caused something to go wrong?
 SH
 Just realised the code here:- http://www.avrfreaks.net/index.php?name=PNphpBB2&file=viewtopic&p=423534 is not for serial mode, i.e. it is in parallel mode.  I am running the screen in serial mode.  I need code for serial mode.
 SH
		| sjharris
				|  Posted: Fri Sep 11, 2009 7:55 am |   |
				| After putting the values in from http://www.crystalfontz.com/forum/showthread.php?t=5123 here; 0xA0
 0xC0
 0xA2
 0x2F
 0x26
 0x81
 0x20
 the screen goes completely black!!  I have tried many different combinations but I cannot get the screen to respond.
 What am I likely to see when I use the LCD_display() command in the post from lun on crystalfontz forum??
 What can be wrong with the screen??
 TIA
 SH
		| sjharris
				|  Posted: Mon Sep 28, 2009 8:58 am |   |
				| After persevering for a long time I have managed to get a feint block on the screen now.  Not a solid black one but a feint grey area. The settings that I have used are:
 (Called in LCD Init)
 ADC - 0xa0
 SHL - 0xc0
 LCD Bias - 0xA2
 VC - 0x2C
 VR - 0x2E
 VF - 0x2F
 Resistor Reg - 0x23
 Ref Voltage Select - 0x81
 Ref Voltage Select - 0x22
 Initial Dis Line - 0x40
 display on - 0xaf
 But when I use the 042_v01.C code and try the dt_lcd_gotoxy(x,y) The screen clears itself and nothing is displayed.
 I am now trying to set the screen to display something by using the dt_lcd_write_dorc(command) function.
  	  | Code: |  	  | dt_cs = 0;
 dt_rs = 1;
 dt_lcd_write_dorc(0x10);  // set column MSB
 dt_cs = 1
 dt_cs = 0;
 dt_rs = 1;
 dt_lcd_write_dorc(0x00);  // set column LSB
 dt_cs = 1
 dt_cs = 0;
 dt_rs = 1;
 dt_lcd_write_dorc(0xB0);  // set page
 dt_cs = 1
 dt_cs = 0;
 dt_rs = 1;
 dt_lcd_write_dorc(0x3E);  // write data
 dt_cs = 1
 dt_cs = 0;
 dt_rs = 1;
 dt_lcd_write_dorc(0x00);  // write data
 dt_cs = 1
 Should this work??  Should I see something on the screen?
 Regards SH
		| sjharris
				|  Posted: Thu Oct 01, 2009 2:37 am |   |
				| I know I can write commands to the screen because I am able to change the contrast of the rectangle that is displayed.  But I cannot send data to the screen. I have set the initial line to 0x40, set the MSB for column to 0x10 and LSB to 0x00.  Then sent data to the screen, I am using this function:-
  	  | Code: |  	  | dt_lcd_write_data(0xF0); dt_lcd_write_command(0xAF);   //Turn on screen
 But I get nothing on the screen.  I have looped this 7 times to see if the data is of the screen but still nothing.
 After initialising the screen should I see the (depending on shade) rectangle (some settings make it grey some make it black and some make it hardly appear).
 Do I need to initialise anything else before I can see the data?
 TIA
 SH
		| sjharris
				|  Posted: Fri Oct 02, 2009 3:44 am |   |
				| OK, so now I have put a scope on the Data and RS lines.  I know that the data is being clocked into the LCD and that the RS is correct, low for command high for data.  I see this happening on the screen. But I still cannot see anything on the screen!!
 I try to initialise the screen to Page = 0, address = 0 and initial line = 0
  	  | Code: |  	  | dt_lcd_write_command(0x40);    //Inital line
 dt_lcd_write_command(0xB0);    //Page address
 dt_lcd_write_command(0x10);    //Column address MSB
 dt_lcd_write_command(0x00);    //Column address LSB
 This should initialise to position 0, 0 shouldnt it?
 Why wont this work??
 TIA
 SH
