thefloyd Guest
advice on use of interrupts |
Posted: Wed Sep 02, 2009 2:40 pm |
As both electronics and weather are a hobby of mine, I'm putting together my own weather station. The current design has a remote/outside sensor board with a PIC16LF876A connected to several sensors, relaying data back to another PIC inside to do other things with the data.
The remote probe should sip as little power as possible. To accomplish this, my design goal is to use an external 32khz crystal on timer1 and sleep the PIC. When the timer rolls over, the PIC should wake up, poll several sensors (SCP1000, SHT15, etc) and report the data collected via a serial output.
How would you guys recommend accomplishing this? My original idea was to have an ISR that did something like:
read_sensor_1();
read_sensor_2();
report_data();
However, I've seen advice that ISRs should be kept as simple as possible. Considering that the routines to read the sensors can be complex, is it advisable to call them inside of an ISR? Is there a better way to accomplish what I want to do? |
Posted: Wed Sep 02, 2009 2:53 pm |
You don't need to use an interrupt routine. This program shows how
to put the PIC to sleep, and then have it wake up when Timer1 rolls
over from 0xFFFF to 0x0000. Timer1 runs from a watch crystal
oscillator connected to the T1OSI and T1OSO pins.
http://www.ccsinfo.com/forum/viewtopic.php?t=28158&start=8
You could take most of the code in main(), and put it in a while(1)
loop. Then it would periodically wake up (every 2 seconds) and
read your sensors. |
thefloyd
Posted: Wed Sep 02, 2009 3:20 pm |
PCM programmer wrote: | You don't need to use an interrupt routine. This program shows how
thank you. That's exactly what I had mapped out in my mind, but couldn't figure out.. |
