DC look up Table
attabros
DC look up Table
PostPosted: Mon Aug 31, 2009 5:09 am     Reply with quote
I have input of 160 V DC ,I have made that scale to 3 volt to analog input to PIC 16F877A ,I want to create a look up table for 32 steps from 00000
to 11111 as the voltage decreases or increses which will output on PORT D.
Kindly Help me out for writing a software.
wireless
PostPosted: Mon Aug 31, 2009 8:38 am     Reply with quote
Hi Attabros
Why do you need a look up table? Just read the ADC (assuming you are using a 3V reference) divide the value by 8 or right shift it 3 times and output it to the port.
Good luck
Terry
attabros
PostPosted: Tue Sep 01, 2009 2:44 am     Reply with quote
Thanks for a quick reply,
Well I have designed an inverter the input will varies from 132.5 VDC to 198 VDC in 32 steps & the output will remain stable at 220 VAC, the reference volt is 160V DC that scale to 3V to AN0 as the voltage increases or decreses the output volt must be at 220 VAC.
S No. A12-A8  O/P AC V   LOAD   Ampere   I/P DC V
 0    00000   220        748W   3.4      198
 1    00001   220        748W   3.4      195.5
 2    00010   220        748W   3.4      194.5
 3    00011   220        748W   3.4      191
 4    00100   220        748W   3.4      190
 5    00101   220        748W   3.4      189.5
 6    00110   220        748W   3.4      186
 7    00111   220        748W   3.4      180.5
 8    01000   220        748W   3.4      178
 9    01001   220        748W   3.4      175.5
10    01010   220        748W   3.4      174.5
11    01011   220        748W   3.4      171
12    01100   220        748W   3.4      169.5
13    01101   220        748W   3.4      168
14    01110   220        748W   3.4      166
15    01111   220        748W   3.4      165.7
16    10000   220        748W   3.4      164.5
17    10001   220        748W   3.4      160.5
18    10010   220        748W   3.4      159
19    10011   220        748W   3.4      156
20    10100   220        748W   3.4      153
21    10101   220        748W   3.4      152.9
22    10110   220        748W   3.4      152
23    10111   220        748W   3.4      150
24    11000   220        748W   3.4      148
25    11001   220        748W   3.4      147.5
26    11010   220        748W   3.4      146.7
27    11011   220        748W   3.4      143.5
28    11100   220        748W   3.4      141.5
29    11101   220        748W   3.4      140
30    11110   220        748W   3.4      139
31    11111   220        748W   3.4      132.5
Thats why I need a look up table. The address A8-A12 will o/p on port D
to switch the output voltages.
Kindly give detail.
attabros
PostPosted: Wed Sep 02, 2009 12:36 am     Reply with quote
Is there any simple way to read the data from Analog & output the data on port D
using the table i given above.
attabros
PostPosted: Wed Sep 02, 2009 5:58 am     Reply with quote
I have write a few lines with respect to the DC volt
but not sure will it work or not can anyone guide me, please help me out
its urgent for me.
#include <16F877A.h>
#device ICD=TRUE
#device adc=8
#FUSES HS                       //High speed Osc (> 4mhz)
#FUSES PUT                      //Power Up Timer
int b,c;
float a;
   setup_adc_ports(ALL_ANALOG);
   setup_psp(PSP_DISABLED);
   setup_spi(FALSE);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
   // TODO: USER CODE!!
While(TRUE)
set_adc_channel(0);
delay_ms(50);
b=read_adc();
a=(b*5/255);
if (a==4) //for 198 DC volt
output_D(0x00);
else if(a==3.9)  //for 195.5 DC volt
output_D(0x01);
else if(a==3.87)  //for 194.5 DC volt
output_D(0x02);
else if(a==3.82)  //for 191 DC volt
output_D(0x03);
output_D(0x00);
PostPosted: Wed Sep 02, 2009 2:39 pm     Reply with quote
Here is a sample program that shows how to use a look-up table to
translate input values to output values.
#include <16F877.H>
#fuses XT, NOWDT, BROWNOUT, PUT, NOLVP
#define ADC_LOWER_LIMIT  132
#define ADC_UPPER_LIMIT  198
// Create a lookup table that translates input
// values from 132 to 198, to output values from
// 31 to 0.  This table will have 67 entries. Note
// that we use 'const' to place this table in ROM,
// to save on RAM usage.
int8 const translation_table[] = {
31,  // 132
31,  // 133
30,  // 134
30,  // 135
30,  // 136
29,  // 137
28,  // 138
// Fill in the remaining table entries, for input values
// from 139 to 194.   If the existing entries are not
// correct, then change them.
2,   // 195
1,   // 196
1,   // 197
0    // 198
int8 translate_adc_value(int8 adc_value)
int8 index;
int8 retval;
// Do a range check on the adc value.  If it's out of range,
// then force it to the lower or upper limit of the acceptable
// range.
if(adc_value < ADC_LOWER_LIMIT)
   adc_value = ADC_LOWER_LIMIT;
if(adc_value > ADC_UPPER_LIMIT)
   adc_value = ADC_UPPER_LIMIT;
// Subtract the lower limit (the offset) from the adc value,
// to get a convenient array index that starts at 0.
index = adc_value - ADC_LOWER_LIMIT;
// Now translate the adc value, to get the output value.
retval = translation_table[index];
// Return the output value.
return(retval);
int i;
// Do a test of the translation routine.
for(i = ADC_LOWER_LIMIT; i < ADC_LOWER_LIMIT + sizeof(translation_table); i++)
    printf("%2u  %u\r", i, translate_adc_value(i));
attabros
PostPosted: Fri Sep 04, 2009 6:00 am     Reply with quote
I have write some lines to the software but its not working
long int  reading;
float a,b;
   setup_spi(FALSE);
   setup_vref(FALSE);
set_adc_channel(0);
delay_ms(50);
reading=read_adc();  //can be 0-1024
a=(reading*5/1023);  //converting into voltage
b=(a*100);
reading=(long int)a,b; //float to long integer
if(b>400)
output_D(0x00);
else if(b>390)
output_D(0x01);
else if(b>387)
output_D(0x01);
output_toggle(PIN_D1);
as i vary the voltages the output at PIN D1 toggles , what changes should
i make so that it will read the voltages & output on port D.
