Receive 7 bits communication
Jasen
PostPosted: Mon Aug 31, 2009 12:59 pm     Reply with quote
I have a device thats send data = 7 bits and stop bit=2. How can i proceed to read this variable using PIC16F648A.
PostPosted: Mon Aug 31, 2009 1:27 pm     Reply with quote
Just don't worry about it!...
When receiving, extra stop bits don't matter.
If you just receive the data as 8bit, one stop, and clear the top bit of the received byte, it'll receive correctly.
Jasen
PostPosted: Mon Aug 31, 2009 1:48 pm     Reply with quote
I create this following test program to make sure that the PIC16F648A will read correctly the 7 bits data.
#use rs232(baud=4800, xmit=pin_b2, rcv=pin_b1)
 if ( getc() == 12) output_high (pin_b6);
With external PC communication program, I simulated sending by RS232 the data 12. The output goes hi only when I set 8 bits data on the PC communication program. With 7 bits, the output keep low.
Tks, Jasen
PostPosted: Mon Aug 31, 2009 2:20 pm     Reply with quote
You are not clearing the top bit (& 0x7F).....
Jasen
PostPosted: Mon Aug 31, 2009 2:52 pm     Reply with quote
Could you give me a Hint how to clearing top Bit.
Tks, Jasen
PostPosted: Mon Aug 31, 2009 3:23 pm     Reply with quote
You missed something... Embarassed
Though clearing a bit is standard C-code Ttelmah did give you the answer. Read his post again...
