hexfet13
floating point problems with pic24F |
Posted: Sat Aug 29, 2009 4:49 pm |
I need to write a simple code with some float variable on a PIC24F but just with a simple assignment in mplab sim appears some strange values.
For example this code ....
#include <24FJ16GA002.h>
#use delay(clock=8000000)
float a;
a=-1;
a=1;
a=0;
... produces these results (value column, on watch window in mplab sim):
a=-1 ==> 4.61853961e-041
a=1 ==> 4.60060299e-041
I've tried to declare float32 instead of float, but with the same strange results.
With a PIC18F everything works fine, then...where is the problem?
My compiler version is 4.072
Thanks!! |
FvM
hexfet13
Posted: Sun Aug 30, 2009 6:07 am |
Thanks for your reply but there's a chance to set the appropriate floating point format in the "value" column in watch window? (sprintf works fine but is uncomfortable to use it) |
FvM
Posted: Sun Aug 30, 2009 7:02 am |
As I reported in the linked thread, I was able to set the correct format in MPLAB V8.20. It either doesn't work in some MPLAB versions, or the original poster didn't manage to find the setting. As I have no problems with displaying float watches, I didn't try to clarify the issue. If there's an MPLAB problem, you should contact Microchip. |
