PIC16F1936 timer enable problem
gpacer68
PostPosted: Fri Aug 28, 2009 7:41 am     Reply with quote
I have changed from the PIC 16f886 to the new micro watt 16F1936. The parts are pin compatible. The code ported over very easily thanks to CCS abstractions. :-) I am currently having a problem making the timers work. I have tried timer0, timer2 and timer4 and none of them will actually tic or start resulting in the interrupt not firing either.
any help would be great.
I am running v4.093 of PCW IDE
#include <16F1936.h>
#include <stdio.h>
#include <stdlib.h>
#fuses noDEBUG   //  debug - in circuit debugger enabled on RB6 and RB7 - DISABLED
#fuses noLVP     //  LVP - low voltage enable - DISABLED
#fuses noFCMEN   //  Fail safe clock monitor - DISABLED
#fuses noIESO    //  IESO - internal / external switch over DISABLED
#fuses BROWNOUT  //  Brown out reset selection bits - 11 BOR  ENABLED
#fuses noCPD     //  CPD - date code protect DISABLED
#fuses noPROTECT //  CP - code protect DISABLED
#fuses MCLR      //  MCLRE - RE3 is MCLR
#fuses noSTVREN
#fuses noPUT     //  PWRTE - power up timer enable bit DISABLED
#fuses INTRC_IO, noWDT
// preprocessor directive that defines fuses for the chip
//application will use the internal oscillator at 8MHz.
//compiler will set INTOSC_IO config bit, and set the internal
//oscillator to 8MHz.
#use delay(internal=4M)
#use rs232(baud=19200, xmit=PIN_C6, rcv=PIN_C7)
unsigned int16 _restart_reason;
#define INTS_PER_SECOND 122
int _new_sec;      // A running seconds counter
int secs;         // A running seconds counter
int int_count;    // Number of interrupts before a second has elapsed
#INT_TIMER0
void timer0_isr(void)
    putc('+');
    if ( --int_count == 0 )
      secs++;
      _new_sec++;
      int_count = INTS_PER_SECOND;
      if ( secs >= 60 ) {
        secs=0;
void timer_init()
   _new_sec  = 0;
   secs      = 0;
   set_timer0(5);
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_64);
You see the 'Timer 0 (AKA RTCC)" in the first comments line? Looking at your program you
should get a toggle on the test pin every 1.6 seconds right? You are using a 4Mhz crystal
so your basic timer0 tick (the time it takes the timer to go up one count) is 1us. You are
using it in 8 bit mode and a prescaler of 64. So timer0 overflows in 1us*2^8*64 = 0.0164 seconds.
 Everytime it overflows you enter the ISR and increase the overflow count by one.
Once counts hits 100 the pin is toggled. So 0.0164*100 = 1.64 seconds.
8Mhz so timer tick is 0.5us
each overflow happens at :
0.5us*2^8*64 = 0.008192 secs
1/0.008192 = 122 overflows/INTS per second
//#separate
#zero_ram
    int b;
    int16 x;
    setup_oscillator( OSC_4MHZ | OSC_PLL_OFF );
    //** get the reason for last reboot for later saving to EEPROM
    _restart_reason = restart_cause();
    switch(_restart_reason)
      case MCLR_FROM_RUN:   //** on reset or WD time out this reason gets set
        printf("mclr\n\r");
      case WDT_TIMEOUT:
        printf("wdt\n\r");
      case NORMAL_POWER_UP:
        printf("norm\n\r");
      case BROWNOUT_RESTART:
        printf("brown\n\r");
      default:
        printf("other\n\r");
    // Set PORT to all output
    set_tris_a(0);
    output_a(0);  //all port A off
    //** all PORTB leds OFF
    set_tris_b(0);
    output_b(0);
    printf("hello !!\n\r");
    delay_ms(2000);
    timer_init();
    output_b(1);
    b=0;
      //** flash status led every second
#if 1
      if ( b == 0 ) {
        output_high(PIN_B0);
        b = 1;
      else {
        output_low(PIN_B0);
        b = 0;
      printf("+ %d", get_timer0());
      if ( _new_sec == 0 )
        continue;
      _new_sec = 0;
      printf(".");
gpacer68
PostPosted: Fri Aug 28, 2009 11:40 am     Reply with quote
Try a simple program which toggles an LED that is connected to pin C0.
Connect a 470 ohm resistor between pin C0 and the anode of the LED.
The connect the cathode of the LED to ground. This assumes the PIC
is running at +5v. This program should toggle the LED on/off at about
a 1 Hz rate. I don't have this PIC to test in hardware, so I don't
guarantee that this will work.
#fuses INTRC_IO,NOWDT,NOPROTECT,BROWNOUT,PUT,NOLVP
#define LED_PIN  PIN_C0
#int_timer1
void timer1_isr(void)
output_toggle(LED_PIN);
output_low(LED_PIN);
setup_timer_1(T1_INTERNAL | T1_DIV_BY_8);
set_timer1(0);
clear_interrupt(INT_TIMER1);
gpacer68
PostPosted: Sat Aug 29, 2009 3:04 pm     Reply with quote
I tried your program and it worked, however when I changed it to use timer0 and I could not get that timer to work. I obviously changed the interrupt handler to account for the new frequency of interrupts with timer0.
In reading the list of changes to the compiler (recall I was at 4.093) it appears that more support for the new midrange PICs were added in newer versions. So I upgraded to 4.098 and the timer0 code worked as is.
So, the summary is, it appears the 4.093 did not fully support the PIC16F1936 timer0 and timer 2/4/6 features of this chip. When I upgraded to 4.098 these timers worked.
Thanks for the help.
gpacer68
