ideas for internet ip project
TOMER
PostPosted: Wed Aug 26, 2009 12:45 pm     Reply with quote
I seek after ideas for robotic project that use internet interface.
Maybe anybody here recognize something like this.
I search after things that are existent.
Steve H
PostPosted: Wed Aug 26, 2009 9:26 pm     Reply with quote
Well - you probably don't want a Ethernet cable interface so you can look at the following for an interface (all wireless),
WiFi - Expensive, but high bandwidth
Bluetooth - cheap, decently reliable
ZigBee - same as Bluetooth, but lower power and less bandwidth.
One company that has loads of wireless solutions is Rabbit Semiconductor - all the solutions that they have are basically wireless modules that could also be hooked up to a PIC. Most of these modules (like the Bluetooth ones) have some sort of Modem like AT command set that can be talked to by a serial port.
Figure out how much power you have an how much bandwidth you need and the solution will be more obvious.
You can use one of CCS Ethernet to PIC solutions for the "other end".
HTH - Steve H.
PostPosted: Thu Aug 27, 2009 11:40 am     Reply with quote
Thanks Steve for your response.
But I search after things that used internet IP protocol.
That can control one thing that is in other city or other country.
If you recognize \ know about applications that used ip protocol
I will glad if you can write it in this chaining.
TOMER
PostPosted: Fri Aug 28, 2009 4:32 am     Reply with quote
UP
