PCD Assembler Error?
Teddy
PostPosted: Tue Jul 01, 2008 11:20 pm     Reply with quote
For a PIC24HJ64GP210 I used the latest CCS Compiler version 4.071.
I used this code to set a timer:
set_timer1 (TMR_INTERNAL | TMR_DIV_BY_8);
It works OK.
When I used this
set_timer1(TMR_INTERNAL | TMR_DIV_BY_64);
the timing is totally out.
The assembler memonics code looks OK.
Has anyone come across similar issue?
Teddy,
dew
PostPosted: Sun Aug 23, 2009 8:30 am     Reply with quote
same CCS Compiler version 4.084
TMR_DIV_BY_1 and TMR_DIV_BY_8 work
TMR_DIV_BY_64 and TMR_DIV_BY_256 not work(can not SET_TIMERX(XXXXX))
PostPosted: Sun Aug 23, 2009 1:01 pm     Reply with quote
Seems like you confused set_timer1() and setup_timer1()!
It doesn't make sense at all to write a mode constant as timer value.
Useful timer function calls are:
setup_timer1(mode,period);
set_timer1(value);
