RC Servo
Thanuja
RC Servo
PostPosted: Sat Aug 22, 2009 9:38 am     Reply with quote
Hi All,
Im trying to workout a RC Servo these days, and Im having a bit trouble.
The Servo is "RKI-1210". If any one who knows how to turn it 90 degrees please let me know. I really appreciate it.
Cheers
PostPosted: Sat Aug 22, 2009 9:46 am     Reply with quote
Here is a good source on how to use servos...
http://www.geocities.com/bourbonstreet/3220/servobasics.html
Once you read that, search on Servo in this forum for software hints.
bungee-
PostPosted: Sat Aug 22, 2009 2:51 pm     Reply with quote
It is written all over the forum about RC servos. Use search. I have written a sample code for driving 8 servos on PIC, HERE is the code.
But generally servos need some kind of PWM with these specifics:
pulse length 1-2ms every 20ms.
So for servo to be at one extreme the pulse should be 1ms .... when you need servo in middle then it is usually 1.5ms (it depends of manufacturer) and to drive it to other extreme pulse should be 2ms. Wink
Try and if you'll still have problems, post the code we'll gladly help.
Thanuja
RC Servo
PostPosted: Sun Aug 23, 2009 2:49 am     Reply with quote
Guys, Thanx a lot for the help.
But I'm still having sm problems. I can't use my PWM modules as I'm using them to drive wheels of the robot. I need to turn the servo 90 degrees using another pin to give the pulse.
It's for a 18F452 pic.
Here's the code that I have been trying. But its not working well.
#include <18F452.h>
#device adc=8
#FUSES HS                       //High speed Osc (> 4mhz)
#FUSES NOOSCSEN                 //Oscillator switching is disabled, main oscillator is source
#FUSES BORV20                   //Brownout reset at 2.0V
#FUSES NOPUT                    //No Power Up Timer
#FUSES LVP                      //Low Voltage Programming on B3(PIC16) or B5(PIC18)
#FUSES NOCPB                    //No Boot Block code protection
#FUSES NOEBTRB                  //Boot block not protected from table reads
#define SERVO_SIGNAL PIN_B4
   setup_adc_ports(AN0_AN1_AN2_AN3_AN4);
   setup_adc(ADC_OFF);
   setup_psp(PSP_DISABLED);
   setup_spi(FALSE);
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_INTERNAL);
   setup_timer_1(T1_INTERNAL|T1_DIV_BY_4);
   setup_oscillator(False);
   setup_timer_2(T2_DIV_BY_1,249,1); // pwm freq. is set 20Hz
 //  setup_oscillator(False);
   setup_ccp1(CCP_PWM);               // configure pwm1 module, pin c2
   setup_ccp2(CCP_PWM);               // configure pwm2 module, pin c1
   // make pin c1 and c2 as outputs
   output_drive(pin_C1);
   output_drive(pin_C2);
   while(true){
      operate_servo();
}// end of main
void operate_servo(){
      output_high(SERVO_SIGNAL);
      delay_ms(2);
      output_low(SERVO_SIGNAL);
      delay_ms(18);
Please note that I am using PWM modules to drive two wheels of the motor. I have not indicated that part of the code.
Thanks.
bungee-
PostPosted: Sun Aug 23, 2009 2:26 pm     Reply with quote
2ms would drive servo to one of the extreme positions. Try to change the delay_ms(2) to delay_us(1500) .... and then experiment with values like that.
Here is the interrupt routine that you can use....
int degrees; // 0=0deg, 1=90deg, 2=180deg <----!!!!
int1 pause_cycle;
#int_TIMER3
void  TIMER3_isr(void)
   if (!pause_cycle)
      Output_high(Servo_pin);
      switch (degrees) {
         case 0: setup_timer3(60535);   // 65535 - (1ms/(4/20MHz))
         case 1: setup_timer3(58035);   // 1.5ms
         case 2: setup_timer3(55535);    // 2ms
      pause_cycle=1; //Next cycle is pause ....
      output_low(servo_pin);
                pause_cycle=0;  //Next cycle is pulse cycle
      // No setting for timer because at this speed it will overflow in 13,5 ms ...
Don't forget to setup timer3 ( setup_timer_3(T3_INTERNAL|T3_DIV_BY_1); ) and of course activate timer3 interrupt ...
Timer3 interrupt routine will take care of servo. So if you want servo to be at 0deg than you set variable degrees=0, to move it to 90° then set degrees=1 .... this is it.
