Missing #FUSES !?!
PICoHolic
Missing #FUSES !?!
PostPosted: Tue Aug 18, 2009 2:03 am     Reply with quote
Hi
PCWHD v:4.097
PIC18F2431
INTRC_IO is not present anymore and it gives the following error: Unknown keyword in #FUSES "INTRC_IO"
PCWHD v:4.097
PIC18F87J50
H4_SW is not present anymore and it gives the following error: Unknown keyword in #FUSES "H4_SW"
Is there any alternatives?
FvM
PostPosted: Tue Aug 18, 2009 2:53 am     Reply with quote
Don't know what's the motivation at CCS to arbitrarily rename #fuses keywords from time to time?
The said #fuses still exist, but got new names.
PICoHolic
PostPosted: Tue Aug 18, 2009 3:05 am     Reply with quote
What new names?
FvM
PostPosted: Tue Aug 18, 2009 4:04 am     Reply with quote
There's a Valid Fuses info menu and an informational comment in the respective *.h file.
PICoHolic
PostPosted: Tue Aug 18, 2009 5:08 am     Reply with quote
Yeah, I checked that but couldn't find any replacement for INTRC_IO for ex.
FvM
PostPosted: Tue Aug 18, 2009 8:49 am     Reply with quote
I checked the V4.097 devices.dat by the Chipedit Tool and found, that the INTRC_IO entry(mask=0f00 value=0800 CW=1) is now missing for PIC18F2331. So it's actually a newly introduced CCS bug. Sorry for previously misleading you.
You can add the fuse entry to devices.dat by Chipedit again.
PICoHolic
PostPosted: Tue Aug 18, 2009 9:01 am     Reply with quote
Thanks, i did that.
Btw, what does CW means?
Thanks again
PostPosted: Tue Aug 18, 2009 9:32 am     Reply with quote
I think CCS has a program that automatically generates the .H files
from the Devices4.dat file. I suspect that they are doing changes to
prepare for the vs. 4.100 release. (And causing new bugs Bummed Out ).
You should report the bugs to CCS support.
PICoHolic
PostPosted: Tue Aug 18, 2009 9:44 am     Reply with quote
I already did. No reply yet!
FvM
PostPosted: Tue Aug 18, 2009 1:10 pm     Reply with quote
CW (the abbreviation used in the CCS Chipeditor Tool) means configuration word.
kidswizz
PostPosted: Fri Feb 22, 2013 7:52 am     Reply with quote
Hi I have the same problem. How can I fix this?
ezflyr
PostPosted: Fri Feb 22, 2013 8:28 am     Reply with quote
Really? In your prior thread you were using the PIC 16F648A, and now you
are using a 18F series PIC? Are you really using the v4.097 compiler?
Seriously, saying "I have the same problem" tacked onto a 4 year old thread
is kind of pointless. Tell us specifically what chip you are using, what
compiler version you are using, and what is the exact error you are getting.
John
kidswizz
PostPosted: Tue Feb 26, 2013 6:08 pm     Reply with quote
Hello John,
It was actually the compiler version that was the problem. Thanks for the reply Smile
