2 dimensional Const char ?
Gabriel
PostPosted: Sat Aug 15, 2009 6:06 am     Reply with quote
Simple question:
I want to declare a - where "want" is more like "what the compiler takes"
Const char Table[8][7] = { "LED1 0", "LED1 1", "LED2 0", "LED2 1", "LED3 0", "LED3 1", "LED4 0", "LED4 1"};
logic tells me that:
Table[2][0] == 'L'
and
Table[5][4]=='3'
why is the second field [7] instead of [6]?
Table[8][x] should be equal to one of the strings, which are 6 chars long.
Position-{ 0 - 1 - 2 - 3 - 4 - 5 - 6 - 7 }
char-----{ L - E - D - 1 - ' ' - 1 - ? - ? }
WTF?
I don't know if I explained my self correctly...
g
CCS PCM 5.078 & CCS PCH 5.093
Gabriel
PostPosted: Sat Aug 15, 2009 6:26 am     Reply with quote
by the way,
the purpose of this is to find one of those forementioned strings
inside a buffer, which is filled by my serial ISR.
thanks
g
PostPosted: Sat Aug 15, 2009 9:20 am     Reply with quote
The strings are _not_ 6 characters long.
A 'string' in 'C', is a _null terminated_ sequence of bytes. You need to count the 'null' as well.
Read a C reference book. This is nothing special to CCS.....
Gabriel
PostPosted: Sat Aug 15, 2009 6:01 pm     Reply with quote
hi,
thanks for the clarification...taking that into account... my problem still persists
i cant find it.. started a new thread...
thanks anyways...
gabriel
drolleman
PostPosted: Sat Aug 15, 2009 6:23 pm     Reply with quote
Table[5][4]=='3' is not correct
Table[5][4]==' ' is a space
if you use the debugger you can use the watch on the varibles.
DROLLEMAN
PostPosted: Sat Aug 15, 2009 6:29 pm     Reply with quote
also there is no such
Table[8][x]
you declared 8 items they are numberd 0 - 7
Table[7] would have "LED4 1" your last entry
Gabriel
PostPosted: Sat Aug 15, 2009 6:48 pm     Reply with quote
hi
yeah.. I miscounted... I wrote the example code by hand...its not a copy paste....
Table[8][x]
you declared 8 items they are numbered 0 - 7
Again... miscounted...I wrote the post in a hurry... I had to go work and had people waiting for me....
Sorry for that...
Dumb mistake.... its not that way in my code..I check anyways just in case...
Thanks anyways...
Again sorry for the bad post...
Maybe you can help me in my new post.... I'm really stuck.
g
