PCD Compiler - explorer 16 pic24 - bugs?
fvnktion
PostPosted: Thu Aug 13, 2009 4:17 pm     Reply with quote
I am just getting started with the PIC24 and its compiler. I am using version 4.083. I have just begun testing on the explorer 16 board and have run into the following issues:
#use delay must be defined at half of the clock frequency where it should be using the actual external clock frequency. The clock is actually 8Mhz, but I had to enter 4Hz in order for the timing to work correctly.
The formatting using the printf state on lcd and rs232 formats as follows:
test UART2
1.239999
Are there many more issues that I will be running into with this compiler for the pIC24/30/33??
Here is the code that was tested:
#include <24fj128ga010.h>
#fuses NOJTAG,NOPROTECT,NOWRT
#fuses HS
#use rs232(baud=9600, UART2, parity=n)
#include <lcd_explorer16.c>
void main(){
int i = 0;
printf(lcd_putc,"\fhello world");
printf(lcd_putc,"\n%3f",1.24);
while(1){
output_a(0xff);
output_a(0x00);
if(i==10){
   printf("\n\rtest UART2\r\n%3f",1.24);
   i=0;
}//if
i++;
}//while
}//main
fvnktion
PostPosted: Fri Aug 14, 2009 9:24 am     Reply with quote
I would really like to get a general consensus on how much the PCD compiler is used and how well it is supported. I really dont want to dive too deeply here with the PCD if I am not going to be getting any support.
Maybe time to traverse over the mplab c30 compiler for this architecture? Or should I look into a upgrade to a newer version of the CCS? Or am i just overlooking something in my basic test program?
Has anyone had good results with this compiler with newer versions, older versions?
PostPosted: Fri Aug 14, 2009 11:25 am     Reply with quote
There aren't many people on the forum who provide support for PCD.
It's mostly FvM. It's better if you edit your title and prefix it with PCD
so he'll notice it. Example:
PCD: explorer 16 pic24 compiler - bugs?
FvM
PostPosted: Fri Aug 14, 2009 1:01 pm     Reply with quote
I don't understand, what you're complaining about PCD's understanding of the %3f format specification. It's according to ANSI C, I think.
If the precision is missing, it is taken as 6
The other point is, that you are apparently expecting PCD to generate code, that sets all clock related registers according to #use delay statement. That's not the case. While OSCON is set during processor reset from the configuration word (either default or as specified by #fuses statements), CLKDIV isn't touched by PCD, so the reset default applies. Consult the PIC24FJ128GA010 manual for details.
It's also instructive to check the actual configuration word settings, either in the PCD *.lst file or better in MPLAB, that is decoding it and also allows manual override for test purposes.
fvnktion
PostPosted: Fri Aug 14, 2009 1:23 pm     Reply with quote
Thanks for the reply. I will look into the timing setting of the registers.
My understanding, based on the ccs manual is that the %3f used in my printf should represent a precision of 3 and type float, but a precision of 6 is used. It also seems that the output in the case of precision 6 would be 1.240000 where the value of 1.24 was given. I suppose this could be due to the complex formatting of the float type?
How have you like the PCD in your uses to date?
PostPosted: Fri Aug 14, 2009 2:54 pm     Reply with quote
You are misunderstanding the manual.
In C, the number in front of the decimal point, is the _minimum field width_. So %3f, simply says print a minimum of 3 characers as an output. Does not affect the precision (part after the decimal point at all...
Now normally the 'filler' (extra character sent to fill unused spaces), is a space. So %3f, will, if given '0', result in two spaces, then the single '0' character.
The precision, is the number _after the decimal_ point in the specifier.
So %.3f, gives three spaces after the decimal.
Now it is also common to not realise that there are quite a few locations already 'used' in the field width. There is a leading character 'reserved' to hold the sign, and the decimal point itself, also uses a location. Also, if a number won't fit in a space specified, extra locations will be used as needed.
Add the decimal point, and you should get what you want.
fvnktion
PostPosted: Fri Aug 14, 2009 3:59 pm     Reply with quote
Very helpful.
Thank you.
