uni_student
Joined: 01 Aug 2007 Posts: 38 Location: AUckland, NEW ZEALAND
Problem with GPS and UART |
Posted: Mon Aug 10, 2009 4:29 am |
Hi, trying to send UTC clock from GPS RMC format to hyperterminal, but all sorts of gibberish is showing. Settings are all correct as have tried to send 'printf("ABC123"),' which works. Any help appreciated!
Note: running on 3.3V, pull down resistor on tx pin, 3.3V rs232 line driver used
Code: | #include <18f1220.h>
#fuses HS,NOWDT,NOPROTECT
#use delay(clock=10000000)
#use rs232(baud=9600, xmit=PIN_B1, rcv=PIN_B4, parity=N, bits=8, ERRORS)
char gps[200], temp[20];
int i, j;
#define LED PIN_B5
void main(){
while(TRUE){
gets(gps);
if((gps[2]=='P')&&(gps[3]=='R')&&(gps[4]=='M')&&(gps[5]=='C')){
output_high(LED);
output_low(LED);
for(i=7;i<=16;i++){
j=i-7;
temp[j]=gps[i];
printf(temp);
mskala
Joined: 06 Mar 2007 Posts: 100 Location: Massachusetts, USA
Posted: Mon Aug 10, 2009 9:38 am |
Knowing the length of GPS sentences, it is practically impossible that your copy includes the string terminator. The string terminator '\0' (or integer 0) is required by all string functions, including printf. You need to add it to the end of any string created the way you're doing it. Otherwise it will print all kinds of junk after where you wanted it to stop. |
bkamen
Re: Problem with GPS and UART |
Posted: Mon Aug 10, 2009 11:18 am |
uni_student wrote: | Hi, trying to send UTC clock from GPS RMC format to hyperterminal, but all sorts of gibberish is showing. Settings are all correct as have tried to send 'printf("ABC123"),' which works. Any help appreciated!
In addition to what mskala says...
NMEA defaults to 4800 baud, not 9600.
While so many GPS's support 9600 (and higher), the safest bet is 4800.
Also, as I have mentioned in another post. Think state machine.
You are gathering a stream of chars from a GPS.
Get chars and wait for '$'....
Start stuffing subsequent chars into a string. Is the char a CR or LF?
End the string with \0
then parse the string someplace else...
Don't forget to stop your ISR (if you have one) from continuing to stuff chars into the holding string while you copy it to a temp holder.
Then release the ISR while you process the string that was just received.
Cheers,
