12F675 need help with configuring comparator and int vref
aruna1
PostPosted: Sun Aug 09, 2009 1:39 am     Reply with quote
hello,
I want to use comparator interrupt.
Currently PIC's pin are used as outputs. I just want to know:
1) Using pin 6 will affect vref? (if I use internal vref).
2) I'm hoping to use pin 7 as both input and output. I need to use pin 7 as comparator input while not using as output. While using as a output I disable comparator interrupt? Is this possible?
I already tried some but comparator works only if I ground pin 6 and pull down pin 7.
I have no idea how to setup comparator and internal vref. I read help file but I still don't understand what is different between vref_high and vref_low, and how to choose this option.
I'm new to ccs c, my compiler version is 4.084.
Here is my code:
#include "C:\Documents and Settings\Aruna\My Documents\fan project\adding timer\main.h"
#PRIORITY COMP,EXT
//A4-buzzer
//A5-count/reset
//A3-IR
//A2-zero cross
//A1-LED
//A0-optoisolator
int speed=0;
int count=0;
int timer0_on=0;
int timer_mode=0;
int16 timer0_count=0;
int timer_set=0;
int time_min=0;
int timer_det_mode = 0;
int timer_set_mode = 0;
int second=0;
int minute=0;
int quater_mili=0;
int first_INT_done=0;
int zero_cross_count=0;
int temp=0;
int A4_int_mode=1;
void set_timer();
void finalize_timer();
void chk_ir();
void beep(INT times,int length);
void led(char mode,INT times,int length);
void read_temp();
void fire(int delay);
//#INT_RA
/*void int_on_change_A4 (void)
if(A4_int_mode==1)
led('r',2,50);
#int_COMP
void  COMP_isr(void)
beep(2,50);
//led('r',3,100);
#INT_EXT
void  EXT_isr(VOID)
   chk_ir ();
   output_low (PIN_A0);
   zero_cross_count++;
   IF (speed == 0)
   else IF (speed == 1)
      IF (zero_cross_count == 5)
         delay_ms (1);
         output_high (PIN_A0);
         zero_cross_count = 0;
         delay_ms (1);
   else IF (speed == 2)
      fire(6);
      //delay_ms (6);
      //output_high (PIN_A0);
   else IF (speed == 3)
   fire(4);
      //delay_ms (4);
   else IF (speed == 4)
      fire(2);
      //delay_ms (2);
   else IF (speed == 5)
         read_temp();
         if(temp>=60 && temp<=62)//for testing
         led('r',1,10);
         delay_ms (1);
         delay_ms (1);
#INT_TIMER1
void  TIMER1_isr(VOID)
   quater_mili++;
   led ('r', 0, 0) ;
   IF (quater_mili == 4)
      quater_mili = 0;
      second++;
      IF (second == 60)
         second = 0;
         minute++;
         /*IF (minute == 1)//for testing
            disable_interrupts (INT_EXT);
            beep (1, 1000) ;
            led ('o', 0, 0) ;
            reset_cpu();
            minute = 0;
            time_min = 0;
            disable_interrupts (INT_TIMER1);
          IF (minute == time_min)//real thing
            beep (1, 1000) ;
            led ('o', 0, 0) ;
            reset_cpu();
            minute = 0;
            time_min = 0;
#INT_TIMER0
void  TIMER0_isr(VOID)
   IF (timer_det_mode == 1)
      IF (timer0_count < 5000)
         timer0_count++;
      else IF (timer0_count >= 5000)
         //timer mode on
         timer_mode = 1;
         disable_interrupts (INT_TIMER0);
         timer0_count = 0;
         first_INT_done = 1;
   IF (timer_set_mode == 1)
      IF (timer0_count < 3000)
         timer0_count++;
      else IF (timer0_count >= 3000)
         timer0_count = 0;
         finalize_timer ();
void count_up()
   output_low (PIN_A5);
   delay_ms (1);
   output_FLOAT (PIN_A5);
void reset()
   output_high (PIN_A5);
   delay_ms (1);
void beep(INT8 times,int length)
int i = 0;
//disable_interrupts(INT_RA4); // today
   FOR (i = 1; i <= times; i++)
      output_high (PIN_A4);
      delay_ms (length);
      //output_low (PIN_A5);
      output_float(PIN_A4);
      IF (i != times)
         delay_ms (length);
  // enable_interrupts(INT_RA4);// today
   IF (length == 0)//default
      length = 50;
   IF (mode == 'o') //turn off
      output_FLOAT (PIN_A1);
   else IF (mode == 'r') //red
      INT i = 0;
      IF (times == 0)
         output_high (PIN_A1);
      ELSE
            delay_ms (length);
            delay_ms (length);
   else IF (mode == 'g') //green
      INT i = 0;
      IF (times == 0)
         output_low (PIN_A1);
      ELSE
            delay_ms (length);
            delay_ms (length);
void finalize_timer() // this code does not run
   led ('r', 0, 0) ;
   beep (3, 50) ;
   reset () ;
   speed = 0;
   timer_mode = 0;
   timer_set = 1;
   timer_set_mode = 0;
   enable_interrupts (INT_TIMER1);
   enable_interrupts (INT_EXT);
void set_timer() // this code runs
   timer_det_mode = 0;
   beep (2, 50) ;
   reset();
   led ('r', 2, 50) ;
   led ('g', 0, 0) ;
   timer0_count = 0;
   timer_set_mode = 1;
   //x = 1;
   enable_interrupts (INT_TIMER0); // eneabling for second time
   time_min = 0;
   WHILE ( ! timer_set)
      IF (! input (PIN_A3) &&time_min <= 270) //time_min should be < 270----- need to add
         delay_ms (1000);
         beep (1, 100) ;
         led ('r', 0, 0) ;
         delay_ms (50);
         led ('g', 0, 0) ;
         timer0_count = 0;
         time_min = time_min + 30;
         count_up ();
VOID chk_ir  ()
   IF ( ! input (PIN_A3))
      count++;
      delay_ms (500);
      beep (1, 50) ;
      IF (speed == 0)
      IF (speed != 5 &&count <= 5)
         count_up ();
         speed++;
      else IF (count == 6)
         speed = 0;
         timer_det_mode = 1;
         enable_interrupts (INT_TIMER0); //eneabling for first time;
         count_up();
         timer0_on = 1;
         led ('g', 0, 0); //green
      else IF (count >= 7)
         count = 0;
         IF (timer_mode == 0)
            led ('o', 0, 0) ;
            first_INT_done = 0;
            reset ();
            speed = 0;
      delay_ms (500);
void read_temp()
   //disable_interrupts(INT_RA4);// today
   setup_adc_ports (sAN3|VSS_VDD);
   setup_adc (ADC_CLOCK_INTERNAL);
   set_adc_channel(3);
   delay_us(10);
   temp=read_adc();
   delay_us(10);
   setup_adc_ports (NO_ANALOGS|VSS_VDD);
   setup_adc (ADC_OFF);
disable_interrupts(INT_COMP);
delay_ms(delay);
output_high(PIN_A0);
delay_ms(1);
output_float(PIN_A0);
enable_interrupts(INT_COMP);
   setup_timer_0 (RTCC_INTERNAL|RTCC_DIV_4);
   setup_timer_1 (T1_INTERNAL|T1_DIV_BY_4);
   //setup_comparator (NC_NC);
   //setup_vref (FALSE);
   setup_comparator(A1_VR);//today
   setup_vref(VREF_HIGH|9);//today
   enable_interrupts(INT_COMP);//today
   output_FLOAT (PIN_A4);
   reset ();
   delay_ms (1000);
   //enable_interrupts(INT_RA4);// today
   enable_interrupts (GLOBAL);
   // TODO: USER CODE!!
   WHILE (1)
      chk_ir ();
      if (first_INT_done == 1)
         first_INT_done = 0;
         set_timer ();
PostPosted: Sun Aug 09, 2009 3:27 pm     Reply with quote
Write a little test program which only uses the Comparator and the
Vref. Get rid of 95% of your existing code. Test it and post it.
Post the results of the test.
The parameters used in the setup_comparator() and setup_vref()
functions are given in the 12F675.h file.
