12F675 invalid preprocessor directive with INT_RA4
aruna1
PostPosted: Sat Aug 08, 2009 9:56 pm     Reply with quote
Hello guys, according to 12F675.h file there is a interrupt INT_RA4.
I tried to setup this interrupt but it gives me "invalid preprocesor
directive". What is the wrong? Here is my code part:
#INT_RA4
void int_on_change_A4 (void)
if(A4_int_mode==1)
led('r',2,50);
and used as
   enable_interrupts (INT_EXT);
   enable_interrupts(INT_RA4);// today
   disable_interrupts (INT_TIMER1);
   disable_interrupts (INT_TIMER0);
   enable_interrupts (GLOBAL);
   // TODO: USER CODE!!
   WHILE (1)
      chk_ir ();
      if (first_INT_done == 1)
         first_INT_done = 0;
         set_timer ();
and here is 12F675.h
////////////////////////////////////////////////////////////////// INT
// Interrupt Functions: ENABLE_INTERRUPTS(), DISABLE_INTERRUPTS(),
//                      CLEAR_INTERRUPT(), INTERRUPT_ACTIVE(),
//                      EXT_INT_EDGE()
// Constants used in EXT_INT_EDGE() are:
#define L_TO_H              0x40
#define H_TO_L                 0
// Constants used in ENABLE/DISABLE_INTERRUPTS() are:
#define GLOBAL                    0x0BC0
#define INT_RTCC                  0x0B20
#define INT_EXT                   0x0B10
#define INT_AD                    0x8C40
#define INT_TIMER1                0x8C01
#define INT_TIMER0                0x0B20
#define INT_EEPROM                0x8C80
#define INT_COMP                  0x8C08
#define INT_RA                    0xFF0B08
#define INT_RA0                   0x010B08
#define INT_RA1                   0x020B08
#define INT_RA2                   0x040B08
#define INT_RA3                   0x080B08
#define INT_RA4                   0x100B08
#define INT_RA5                   0x200B08
#list
thanks
PostPosted: Sat Aug 08, 2009 10:37 pm     Reply with quote
Always post your compiler version. We don't remember it from previous
threads.
aruna1
PostPosted: Sat Aug 08, 2009 11:11 pm     Reply with quote
version is 4.084
PostPosted: Sat Aug 08, 2009 11:52 pm     Reply with quote
Here is the explanation:
There is only one "interrupt on change" interrupt. It's called #INT_RA.
But, each pin (GP0-GP5) can be individually enabled for the interrupt-on-
change feature. So the interrupt routine itself will always only have
#INT_RA above it. But in your code, for the enable_interrupts() and
disable_interrupts() functions, you should use INT_RA0 to INT_RA5 as
the parameter. See the example below:
#include <12F675.h>
#fuses INTRC_IO, NOWDT, NOMCLR, PUT, BROWNOUT
#int_ra
void int_ra_isr(void)
int8 temp;
temp = input(PIN_A4); // Read pin to clear mismatch condition
// There is only one "INT_RA" interrupt.  Clear it.
clear_interrupt(INT_RA);
// Enable interrupt-on-change for pin A4 only.
aruna1
PostPosted: Sun Aug 09, 2009 1:21 am     Reply with quote
So interrupt code will only run for changes in A4? and it will not run even other pins are changing?
edit:
i just checked its working
thanks PCM
