Joined: 02 Jun 2009 Posts: 123 Location: The Netherlands
wake up from sleep on pin change 10F222
Posted: Fri Aug 07, 2009 3:49 am
Is there a function which can be used when the 10F222 is waked up from sleep due to a pin change? In the datasheet there is a GPWUF flag which is set when the pic is waked up from sleep from pin change. In the 10F222.h file there a some options with the restart_cause() but not "on pin change".
I want to change a variable when the pic wakes up from sleep. So any other option is also welcome.
IDE: 4.092
mvanvliet
Posted: Fri Aug 07, 2009 5:13 am
Maybe I've already solved this problem with adding the following to my program:
