		| Author | Message |
		| frierray
				| PWM1 and Timer1 problems |
				|  Posted: Thu Aug 06, 2009 1:19 pm |   |
				| All,
 I was wondering if I could get some input from the group.  The following is a small part of some PWM code.  The PWM users PWM1 and Timer 2.
  	  | Code: |  	  | // Set up PWM
 set_pwm1_duty(0);              // This sets the on time
 setup_ccp1(CCP_PWM);           // Configure CCP1 as a PWM
 setup_timer_2(T2_DIV_BY_1, 127, 1);    // Set Parms
 I am also using Timer 1 to determine the time a switch is pressed.
 Problem is; when I enable the interrupts (enable_interrupts(GLOBAL);) the PWM for loop runs the first time and then stops.  Is it valid to use the PWM1 and Timer1 for two different functions?
 I am using a 18f252 and compiler 4.073.
 Thanks, Ray
 The following is some of the code I have written.
  	  | Code: |  	  | void main (void)
 // Set up int for t1 for switch timer
 // T1 timer used for key switch management
 setup_timer_1(T1_INTERNAL | T1_DIV_BY_1);  // T1 clk = 20 MHz
 set_timer1(TIMER1_PRESET);
 // Main system loop
 if(!input(sw_left))                 // look for Left Switch low
 Miliseconds = 0;
 clear_interrupt(INT_TIMER1);
 delay_ms(10);          // debounce
 if(input(sw_left))     // look for Left Switch high
 move_back();          // move carirer to home
 if(Miliseconds > 500)
 while(!input(sw_left)){}
 hard_stop();           // Stop now
 void move_back(void)
 carrier_stat=1;            // 0 = stop, 1 = moving home, 2 maving DR
 // Set direction = back to home
 output_bit(direction, back);     // Set Direction = Back)
 ramp_up();
 void move_forward(void)
 carrier_stat=1;                             //
 output_bit(direction, forward);     // Set Direction = Back)
 ramp_up();
 void ramp_up()
 // Set up PWM
 ml=0;                              // reset ml counter
 motor_speed=50;                   // motor speed start
 for (ml=51;ml<=254;++ml)          // loop for ramp up
 motor_speed=((motor_speed*sp_factor));   // Set motor to x%
 set_pwm1_duty(motor_speed);              // This sets the on time
 delay_ms(5);                             // loop timer 5 ms
 motor_speed=motor_speed+1;               // inc the loop 1
		| PCM programmer
				|  Posted: Thu Aug 06, 2009 2:57 pm |   |
				|  	  | Quote: |  	  | clear_interrupt(INT_TIMER1); enable_interrupts(INT_TIMER1);
 You don't have (or didn't post) a #int_timer1 interrupt routine.
 You need one.
		| frierray
				|  Posted: Thu Aug 06, 2009 3:14 pm |   |
				| PCM Programmer;
 I forgot to include it with the post.  Here it is:
 #define TIMER1_PRESET (65536 - 5000)      // Interrupt every 5000 counts
 // t1 timer used for key switch management
 #int_timer1
 void timer1_isr(void)
 miliseconds++;
 I am using it to count milliseconds.  In my code I need to know if a button is pressed and released or held down.  If the count is > 500, it is assumed the button is held.  There is a different action taken if it is pressed and released or held.
 The PWM is controlled by a for loop.  (If there is a better way to do this, please let me know)  However, the for loop works great until I turn on the enable_interrupts(GLOBAL);   After that the for loop only starts one pass and then stops.  Control returns to my button code.
 Any thoughts you have would be a big help.
 Ray
 void ramp_up()
 // Set up PWM
 | You cannot post new topics in this forum You cannot reply to topics in this forum
