how to make a input
aruna1
how to make a input
PostPosted: Thu Aug 06, 2009 7:27 am     Reply with quote
Hello guys. I'm trying use a tristate switch through GP1 pin of 12F675.
What I want to know how to make GP1 pin an input?
Will output_float() do the trick?
SherpaDoug
PostPosted: Thu Aug 06, 2009 7:38 am     Reply with quote
In the default compiler set-up simply reading the pin with the input() function causes the compiler to make the pin an input before reading it. Output_float() will tri-state the pin without consuming any memory to put the result in, but it is rarely necessary.
If you use fixed I/O or fast I/O instead of the default standard I/O you will need to set pin direction explicitly. But those are only for special occasions.
aruna1
PostPosted: Thu Aug 06, 2009 7:44 am     Reply with quote
Ok so what should I write? (I don't want to read any input data. Just to make it as an input).
aruna1
PostPosted: Thu Aug 06, 2009 9:20 am     Reply with quote
output_float() is working
