sindyme
help me about 18F63j11 |
Posted: Wed Aug 05, 2009 10:28 pm |
My PIC of 18F63J11 can't work !
I use external crystal at 8Mhz.
I look "CCS Project wizard" that it have
1. High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
2. High speed osc with SW enabled 4x PLL
3. External clock
4. External Clock with SW enabled 4x PLL
I select kind of 1 same 18F452 , but I use "HS" on PIC18F63J11 can't work.
Please help me Orz !!
My 18F63j11 .H file past it
Code: | #FUSES NOWDT
#FUSES WDT128
#FUSES HS
#FUSES NODEBUG
#FUSES NOXINST
#FUSES STVREN
#FUSES NOPROTECT
#FUSES FCMEN
#FUSES IESO
#FUSES PRIMARY
#FUSES RESERVED
and main
setup_psp(PSP_DISABLED);
setup_spi(SPI_SS_DISABLED);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
enable_interrupts(INT_RDA);
enable_interrupts(INT_RDA2);
bkamen
Posted: Wed Aug 05, 2009 11:27 pm |
Is your main really like that or more like:
void main ( void ) {
setup_wdt(WDT_OFF);
setup_vref(FALSE);
while (1) {
please list more about compiler version, your FULL file... there's items missing from your post that need to be answered...
THanks,
sindyme
Posted: Wed Aug 05, 2009 11:47 pm |
My CCS version is 4.084
and my main
setup_wdt(WDT_OFF);
//setup_timer_0(RTCC_INTERNAL);
setup_vref(FALSE);
//delay_ms(500);
printf("Testing.....");
output_high(pin_B0); // Link a LED. if PIC work will ON
for(;;)
printf("Test Test");
bkamen
Posted: Thu Aug 06, 2009 9:42 am |
unless you have service routines for your interrupts, I wouldn't enable them if I were you until you define something to handle them.
Ok, and now for the code prior to the main() ??
Do you have a #device <18F63j11.h>
You're using printf, so you'll need some #use rs232 statement.
Also, consider doing something that repeats..
like
while (1) {
printf("Hello World\r\n");
output_high (LED);
output_low(LED);
