lcd.c driver file
UDIPTA
lcd.c driver file
PostPosted: Sat Aug 01, 2009 12:01 am     Reply with quote
I would like to use port C of pic16f876a to drive lcd. But standard lcd driver lcd.c uses port B or port D. Can it be modified for port C utilization? If yes, then where do I have to change in the code?
I do not want to use flex lcd as it creates some problems.
Please say how standard lcd.c can be used in my program.
anandpv2009
PostPosted: Tue Aug 04, 2009 11:58 am     Reply with quote
I am also looking for such a driver. I can't use the port as output while using flex_lcd driver. I think it is not just a easy task......
bkamen
Re: lcd.c driver file
PostPosted: Tue Aug 04, 2009 12:16 pm     Reply with quote
in LCD.C
#ifndef LCD_DATA_PORT
   #if defined(__PCB__)
      #define LCD_DATA_PORT      0x06     //portb
      #define set_tris_lcd(x)   set_tris_b(x)
   #elif defined(__PCM__)
      #define LCD_DATA_PORT      getenv("SFR:PORTD")     //portd
   #elif defined(__PCH__)
   #elif defined(__PCD__)
   #endif
#endif
You change it to the port you want.
PORTC would be your answer.
But also look closely at the header...
////  Example of pin access:                                               ////
////     #define LCD_ENABLE_PIN  PIN_E0                                    ////
////     #define LCD_RS_PIN      PIN_E1                                    ////
////     #define LCD_RW_PIN      PIN_E2                                    ////
////     #define LCD_DATA4       PIN_D4                                    ////
////     #define LCD_DATA5       PIN_D5                                    ////
////     #define LCD_DATA6       PIN_D6                                    ////
////     #define LCD_DATA7       PIN_D7                                    ////
Don't forget to define your control pins.
-Ben
