Well there is a slight problem for me.
Can I convert a hex value (which I get as char byte) to decimal value and then transmit that as my output ?
I am using C to program my 16F76.
Posted: Tue Aug 04, 2009 12:17 am
1. What device sends the "hex value" to your PIC ?
2. Explain what you mean by a "char byte".
myumair
Posted: Tue Aug 04, 2009 3:41 am
well ad7705 which is operating with pic in SPI mode sends that data and it is 16 bit long so PIC reads that twice from the adc register and store that in a stack [2] each 8 bits long.
so i wanted to converted that data in a decimal form. it is possible?
as i hv to send this to a bluetooth transmitter in UART mode.
mkuang
Posted: Tue Aug 04, 2009 8:21 am
Let's call your high byte High_Byte, your low byte Low_Byte, and the assembled value Final_Value for example. You can try something like:
long Final_Value;
char High_Byte = stack[0];
char Low_Byte = stack[1];
