interrupt priority order in 12F675
aruna1
PostPosted: Sat Aug 01, 2009 9:12 pm     Reply with quote
Guys, is there interrupt priority order in 12F675? Like if both external interrupt and timer interrupt occur at the same time, which interrupt service routine will run first? Is there any way we can set priorities?
And can we use the comparator interrupt as zero voltage detector?
tester
Re: interrupt priority order in 12F675
PostPosted: Sun Aug 02, 2009 1:44 am     Reply with quote
#priority timer1, ext
aruna1
PostPosted: Sun Aug 02, 2009 1:49 am     Reply with quote
thanks
PostPosted: Sun Aug 02, 2009 2:08 am     Reply with quote
As a further comment, if you don't have a 'priority statement, the priority is defined by the order the interrupt handlers are placed in the source code.
There is no hardware priority on any of the 12, or 16 chips, and all the order, or the priority statement does, is determine the sequence in which the bits will be 'polled' in the global handler that CCS generates for you.
aruna1
PostPosted: Sun Aug 02, 2009 2:19 am     Reply with quote
nice
