mkent
PCM programmer 10,000 posts |
Posted: Thu Feb 19, 2009 1:09 am |
Congratulations and thank-you for your gracious help over many years. |
Posted: Thu Feb 19, 2009 3:56 am |
Congratulations from me too!!!
In the past years I've learned a lot from reading PCM's posts in this forum and I hope he will continue giving support for a long time to come.
It would be a nice gesture for CCS to provide a free upgrade, then we can call you 'PCWH Programmer'??? ![Razz](images/smiles/icon_razz.gif) |
arunb
RE; |
Posted: Thu Feb 19, 2009 7:18 am |
congratulations !!!
Many times when I needed help, your advise was always helpful and instructive.
Thank you for all the help..
arunb |
Posted: Thu Feb 19, 2009 9:32 am |
i thought it was more like 0x10000 posts -
well done ! |
Posted: Thu Feb 19, 2009 6:50 pm |
I think I've been on the forum since at least 1999. That's about 10 years.
That's about 1000 posts/year which works about to about 3 posts a day.
Seems like I post more than that. |
Sergio
Joined: 16 Oct 2003 Posts: 11 Location: Arkansas, USA
Posted: Thu Feb 19, 2009 10:06 pm |
It's not so much the quantity of the messages but the quality.
Thanks PCM. You've made quite a difference to this forum. _________________ Sergio |
pyu
Posted: Fri Feb 20, 2009 2:10 am |
Congratulations PCM programer !!! |
Posted: Fri Feb 20, 2009 3:28 am |
I'd suspect it may actually be more than this.
When the forum was updated a few years ago, people had to change their 'ID'. I'd suspect this is actually 10000 posts _since that update_.
So you'd probably have to add something like another 50%, to get the 'real' figure, since he joined....
The great thing about PCM programmer, is that his posts have one of the highest 'accuracy' ratings here, and also he seems able to find things with the search, better than just about anyone else.
Magic.
Kova
Posted: Fri Feb 20, 2009 4:40 am |
Thanks PCM ![Razz](images/smiles/icon_razz.gif) |
treitmey
Posted: Fri Feb 20, 2009 8:24 am |
Thanks for all the help and dedication.
You have a very keen eye for spotting the problem.
Keep up the good work.
Tim |
mmprestine
Joined: 13 Jan 2004 Posts: 29 Location: Green Bay, Wisconsin
Posted: Fri Feb 20, 2009 8:34 am |
Great contributions over the years! |
temopic
Posted: Fri Feb 20, 2009 1:25 pm |
The best support here is from PCM Programmer,
Thanks from Mexico |
Posted: Fri Feb 20, 2009 1:32 pm |
Thanks. But I disagree. I do a lot of example or demo programs
and I like to help people with writing drivers. But, there are a lot of
aspects of PIC programming that I don't cover. Ttelmah gives very
detailed explanations of how things work. asmallri give good support
on TCP/IP topics. ckeilstra has helped a lot on MMC/SD support.
FvM helps a lot on PCD compiler issues. There are many others. |
dexxsterlab
Posted: Sat Aug 01, 2009 7:56 am |
PCM programmer wrote: | Thanks. But I disagree. I do a lot of example or demo programs
Many thanks also from me ! You are really my reference point ! As you say, Ttelmah and so on are also the most reliable sources of information on this forum, so thanks them too. I wish you all the best. |
Salenko
Posted: Mon Aug 03, 2009 2:58 am |
much respect to you PCM,
there is many people today who use CCS compilers thanks to this forum.
I hope that "trainee" programmers like me can someday give similar help here . , I wish all the best for the active members of the forum.
Ttelmah certainly wrote thousands of posts but as he is a guest we can't know the exact number. ![Wink](images/smiles/icon_wink.gif) |
