Problem with crash
filjoa
Problem with crash
PostPosted: Fri Jul 31, 2009 2:25 pm     Reply with quote
Hi
I make a program for controller lights of my car but it crash many times, and I need turn off power for it restart...
This is my circuit:
This is my program:
#include <12F683.h>
#fuses NOWDT,INTRC_IO, NOCPD, NOPROTECT, MCLR, NOPUT, BROWNOUT, IESO, FCMEN
#define LEDS PIN_A4
#define ALARMON PIN_A1
#define ALARMOFF PIN_A0
#define DOORS PIN_A2
#define IGN PIN_A5
int16 i;
int8 aux=0;
output_low(LEDS);
   if (input(ALARMON)==0) output_low(LEDS);
   if (input(ALARMOFF)==0) output_low(LEDS);
   if (input(DOORS)==1) output_low(LEDS);
   if ((input(ALARMON)==1) && (input(IGN)==0))
      output_high(LEDS);
      for (i=0;i<=40;i++)
         if (input(IGN)==1) break;
         if (input(ALARMOFF)==1) break;
   if (input(DOORS)==0)
      output_high(LEDS);
      while(DOORS!=1);
      for (i=0;i<=40;i++)
Someone have an idea how make this crashes?
kind regards
PostPosted: Fri Jul 31, 2009 3:06 pm     Reply with quote
output_high(LEDS);
while(DOORS!=1);
for (i=0;i<=40;i++)
The line in bold is wrong. Can you see the error ?
filjoa
PostPosted: Fri Jul 31, 2009 5:03 pm     Reply with quote
Hi
why this line is wrong?
on PIN "DOORS" it stay at 5V when I close the doors and go to 0V when I open.
on PIN "Signal Doors Open" I have one pulse of 12V for central loock
on PIN "Signal Doors Close" I have one pulse of 12V for central loock
on PIN "IGN" I have 12V when I put key ON
is possible I need put pull-down on "Signal Doors Open", "Signal Doors Close" and "IGN"?
You think which program stay wrong? Confused
PostPosted: Fri Jul 31, 2009 5:18 pm     Reply with quote
Look at it closely. Compare that line to all the other lines that have
'DOORS' in them. What is missing ? There is one thing.
filjoa
PostPosted: Fri Jul 31, 2009 6:14 pm     Reply with quote
Hi
I write "while(DOORS!=1); " for program wait there at I close the doors...
don't stay correct my thought? Confused
PostPosted: Fri Jul 31, 2009 6:43 pm     Reply with quote
What is 'DOORS' ? It's this:
What is 'PIN_A2' ? Look in 12F683.h to find this:
#define PIN_A2  42
So 'DOORS' is the number 42.
With that knowledge, look at your test:
while(DOORS!=1);
Then substitute the value for 'DOORS' in that statement:
while(42 != 1);
That's your code. That's what it's doing. I ask you, is that correct ?
What should you do to fix it ? Look at your other statements that use
the 'DOORS' value.
filjoa
PostPosted: Sat Aug 01, 2009 8:17 am     Reply with quote
Hi
I don't see the bug... problem is because I need have
while(input(DOORS)!=1);
I can see that when post my problem.. thanks for help
PostPosted: Sat Aug 01, 2009 2:02 pm     Reply with quote
The point is that 'DOORS', is not the value of the input pin. It is a numeric value, which allows specific functions to access the pin. Your test, does not use these functions....
