ccs-c to c# dll
the4thfabregas
ccs-c to c# dll
PostPosted: Sat Jul 25, 2009 9:04 am     Reply with quote
Hi all,
I am developing a c# application. I have a program that I developed with ccs-c. I need to use this program in my c# program. Therefore, I need something that converts my ccs-c program to c# dll file.
Any help appreciated.
Thanks in advance...
Rohit de Sa
PostPosted: Sat Jul 25, 2009 10:11 am     Reply with quote
CCS-C is a C-to-PIC compiler. I think what you're looking for is a C#-to-x86 compiler.
This is a free C# compiler + IDE (there may be better ones out there :-P ) : http://www.microsoft.com/express/vcsharp/
Rohit
the4thfabregas
PostPosted: Sat Jul 25, 2009 10:34 am     Reply with quote
I created a project in ccs-c pic c compiler.
One of my file is health_control.h
void nigth(signed int a){
         switch(a){
void evening(signed int a){
         switch(a){
void morning(signed int a){
         switch(a){
and I make a program with using c#. User put values in a LinkedList.
For example:
values1: 1 values2:10
values1: 2 values2:20
values1: 3 values2:30
values1: 4 values2:40
values1: 5 values2:50
I want take these values and put in my healthcontrol.c
and create a file like this
         switch(a){
         switch(a){
         switch(a){
health.control.c created by ccs-c picc compiler and I take values c#.
How I can put my values which I created on c# to my healthcontrol.c which created on ccs-c pic c compiler?
Rohit de Sa
PostPosted: Sat Jul 25, 2009 8:29 pm     Reply with quote
I don't really understand what you are trying to do. Do you want insert those values into *after* compiling the CCS file? If so, you'll have to use a different approach. But please make yourself more clear.
A couple of questions:
- Umm, are you familiar with programming in C? The format of the 'switch' is wrong.
- What are you using C# for? Is it to create a user interface (UI)?
Rohit
the4thfabregas
PostPosted: Sun Jul 26, 2009 5:08 am     Reply with quote
i make temp optimization program with ccs-c pic compiler
i split a day three part.
morning,evening and night
i make a program in c#. my c# program take values from user for temp.
for example;
         case  5:  ic=76;break;
         case  6:  ic=75;break;
         case  7:  ic=73;break;
         case  8:  ic=71;break;
         case  9:  ic=70;break
i created this values on c#. and i want take these values put my ccs-c pic file and compile it
my c# program take values from user.
PostPosted: Sun Jul 26, 2009 8:54 am     Reply with quote
Most of us use the Flash EEPROM to store 'user' values or calibration constants. That way you can have one program and binary image and then you can, at calibration time change the EEPROM values as required. A simple serial connection can be used to change the values. I suppose you can use the debugger to save change the EEPROM too, but I have not done it that way.
You can certainly also do this your way with C# - it is a simple thing to replace strings using C#.
Set your constants up as defines like,
#define const_1 100
#define const_2 220
In your C# program all you have to do is read each line and look for the "#define const_x" then replace the number at the end of the line.
Save the file again and then feed it to the command line compiler.
HTH - Steve H.
Rohit de Sa
PostPosted: Sun Jul 26, 2009 9:09 am     Reply with quote
So from what I understand you want to:
1. take some values from the user;
2. use those values in a C# program to generate some sort of values
3. use the generated values as data in a CCS-C source file
Is that correct?
What you wish to do is to read data from a file on your PC using CCS. I don't think there are file IO directives/functions in CCS. But you could easily create a header file using C# using file output functions. The header file could contain an array with the required values. Include this header in your CCS-C source.
Here's a quick primer on file IO using C# http://www.devhood.com/Tutorials/tutorial_details.aspx?tutorial_id=400
I'm not too good with C#, but to do something like this, I'd write a quick and dirty QBasic program with lines that look like this:
open "temp.h" for output as #1
input value[0]
input value[1]
input value[2]
for i=0 to 9
       some_string$="some_array[" + str$(i) + "]=" + str$(value[i]) + ";"
       print #1, some_string$
next i
end
This code basically creates a file called temp.h on my PC. It takes in user inputs and stores them in the array *value[]* . It uses simple string manipulation functions to output text, the fourth line of which looks like this:
some_array[3]=54;
I would then write:
#include <temp.h>
in my CCS source file.
Dirty, but it works. Razz
Rohit
