filjoa
| truth table |
Posted: Tue Jul 21, 2009 6:57 pm |
Hi
What is better way to make a truth table?
I have one PIC for make this decoder, X0 to X4 is inputs and output is other pins...
I make some like that:
#include <16F876A.h>
#define X0 PIN_C6
#define X1 PIN_C7
#define X2 PIN_B0
#define X3 PIN_B1
#define X4 PIN_B2
while (TRUE)
//###################### relay OFF #######################
if ((input(X4)==0) && (input(X3)==0) && (input(X2)==0) && (input(X1)==0) && (input(X0)==1)) output_low(PIN_B6); //R1
if ((input(X4)==0) && (input(X3)==0) && (input(X2)==0) && (input(X1)==1) && (input(X0)==0)) output_low(PIN_B5); //R2
if ((input(X4)==0) && (input(X3)==0) && (input(X2)==0) && (input(X1)==1) && (input(X0)==1)) output_low(PIN_B4); //R3
if ((input(X4)==0) && (input(X3)==0) && (input(X2)==1) && (input(X1)==0) && (input(X0)==0)) output_low(PIN_B3); //R4
if ((input(X4)==0) && (input(X3)==0) && (input(X2)==1) && (input(X1)==0) && (input(X0)==1)) output_low(PIN_C5); //R5
if ((input(X4)==0) && (input(X3)==0) && (input(X2)==1) && (input(X1)==1) && (input(X0)==0)) output_low(PIN_C4); //R6
if ((input(X4)==0) && (input(X3)==0) && (input(X2)==1) && (input(X1)==1) && (input(X0)==1)) output_low(PIN_C3); //R7
if ((input(X4)==0) && (input(X3)==1) && (input(X2)==0) && (input(X1)==0) && (input(X0)==0)) output_low(PIN_C2); //R8
if ((input(X4)==0) && (input(X3)==1) && (input(X2)==0) && (input(X1)==0) && (input(X0)==1)) output_low(PIN_C1); //R9
if ((input(X4)==0) && (input(X3)==1) && (input(X2)==0) && (input(X1)==1) && (input(X0)==0)) output_low(PIN_C0); //R10
//###################### relay ON #######################
if ((input(X4)==1) && (input(X3)==0) && (input(X2)==0) && (input(X1)==0) && (input(X0)==1)) output_high(PIN_B6); //R1
if ((input(X4)==1) && (input(X3)==0) && (input(X2)==0) && (input(X1)==1) && (input(X0)==0)) output_high(PIN_B5); //R2
if ((input(X4)==1) && (input(X3)==0) && (input(X2)==0) && (input(X1)==1) && (input(X0)==1)) output_high(PIN_B4); //R3
if ((input(X4)==1) && (input(X3)==0) && (input(X2)==1) && (input(X1)==0) && (input(X0)==0)) output_high(PIN_B3); //R4
if ((input(X4)==1) && (input(X3)==0) && (input(X2)==1) && (input(X1)==0) && (input(X0)==1)) output_high(PIN_C5); //R5
if ((input(X4)==1) && (input(X3)==0) && (input(X2)==1) && (input(X1)==1) && (input(X0)==0)) output_high(PIN_C4); //R6
if ((input(X4)==1) && (input(X3)==0) && (input(X2)==1) && (input(X1)==1) && (input(X0)==1)) output_high(PIN_C3); //R7
if ((input(X4)==1) && (input(X3)==1) && (input(X2)==0) && (input(X1)==0) && (input(X0)==0)) output_high(PIN_C2); //R8
if ((input(X4)==1) && (input(X3)==1) && (input(X2)==0) && (input(X1)==0) && (input(X0)==1)) output_high(PIN_C1); //R9
if ((input(X4)==1) && (input(X3)==1) && (input(X2)==0) && (input(X1)==1) && (input(X0)==0)) output_high(PIN_C0); //R10
//###################### relay ALL OFF #######################
if ((input(X4)==1) && (input(X3)==0) && (input(X2)==0) && (input(X1)==0) && (input(X0)==0)) //ALL OFF
what you think?
kind regards |
Rohit de Sa
Posted: Tue Jul 21, 2009 9:02 pm |
One way of doing this, instead of writing tons of code (which could be host to several errors) is to use an 'overlay' approach.
You can create a 'structure' of sorts, in which different pins are mapped to bits in a byte, and input/output to pins in that structure by modifying that byte.
With this method, instead of | Code: | | if ((input(X4)==0) && (input(X3)==0) && (input(X2)==0) && (input(X1)==0) && (input(X0)==1)) output_low(PIN_B6); //R1 | you'd be able to do something like this | Code: | if (my_byte==0x03)
{some_other_byte=0x08;} | where the bits in *my_byte* are mapped to pins.
Read this http://ccsinfo.com/forum/viewtopic.php?t=35816 and http://www.ccsinfo.com/forum/viewtopic.php?t=18949&start=6
Rohit |
filjoa
Posted: Wed Jul 22, 2009 8:06 pm |
Hi
I try make with 16F876 an decoder and put combination with 18F452.
on 18F452 I have:
void RELAY1ON ()
output_low (PIN_C1);
output_low (PIN_C2);
output_low (PIN_C3);
output_high (PIN_C4);
void RELAY2ON ()
output_low (PIN_C4);
void RELAY3ON ()
output_high (PIN_C3);
void RELAY4ON ()
output_high (PIN_C2);
void RELAY5ON ()
void RELAY6ON ()
void RELAY7ON ()
void RELAY8ON ()
output_high (PIN_C1);
void RELAY9ON ()
void RELAY10ON ()
//##################### RELAY OFF #####################
void RELAY1OFF ()
output_low(PIN_C0);
void RELAY2OFF ()
output_low(PIN_C0);
void RELAY3OFF ()
output_low(PIN_C0);
void RELAY4OFF ()
output_low(PIN_C0);
void RELAY5OFF ()
output_low(PIN_C0);
void RELAY6OFF ()
output_low(PIN_C0);
void RELAY7OFF ()
output_low(PIN_C0);
void RELAY8OFF ()
output_low(PIN_C0);
void RELAY9OFF ()
output_low(PIN_C0);
void RELAY10OFF ()
void RELAYALLOFF ()
output_high (PIN_C0);
and on 16F876 I have
while (TRUE)
but it don't work
if for example I call RELAY1ON(); on 18F542
it turn on and turn off all relays very quickly
some one can help me for make this decoder?
kind regards |
Rohit de Sa
Posted: Wed Jul 22, 2009 9:46 pm |
It is possible that the relays are causing glitches in the supply.
-How are you powering/activating the relays? Separate supply with a driver? Or is the supply shared between the relays and microcontroller?
-Are you using a snubber diode across your relays?
-Instead of relays use LEDs, and see if you face the same problem.
-Have you got a pull up on the MCLR pins of the microcontrollers?
Rohit |
filjoa
Posted: Wed Jul 22, 2009 10:08 pm |
Hi
Thanks for opinions...
Problem stay on hardware...
Now all stay fine. Thanks  |
