pdfnow Guest
Create a PDF file on an SD card ? |
Posted: Mon Jul 20, 2009 4:56 pm |
I can read/write to sd cards using a PIC18f2620. Does anyone think there is a way to create a simple pdf file on the card with text only. If the use want to save a file with Hello World on the first line, what would the pdf file look like? Could it be created with CCS C and fit on a 18F2620? Thanks. |
Rohit de Sa
Posted: Mon Jul 20, 2009 8:40 pm |
I don't think there is an easy way to create a pdf file using just text. You'd have to understand different parts of a PDF, which, IMHO, is not an easy task. PDFs are based on the PostScript language, and 'carry' with themselves several formatting options, images, strings, etc. Infact, a PDF is more like a script file, rather than a simple 'document'. This 'script file' like behaviour is what makes it platform independent.
From wiki: Quote: | The PDF combines three technologies:
* A subset of the PostScript page description programming language, for generating the layout and graphics.
* A font-embedding/replacement system to allow fonts to travel with the documents.
* A structured storage system to bundle these elements and any associated content into a single file, with data compression where appropriate.
Rohit |
mbradley
Joined: 11 Jul 2009 Posts: 118 Location: California, USA
Posted: Tue Jul 21, 2009 1:30 am |
I have in the past made a pdf template, then did a replace at specific byte locations to put my own text. Open a pdf in a hex editor, find the locations, that might help.
Other than that, look for some php source on creating pdf's. |
