Dual H-Bridge motor control
ricard0g0mes
PostPosted: Fri Jul 17, 2009 5:49 am     Reply with quote
I'm trying to use this motor driver in my project:
http://www.sparkfun.com/commerce/product_info.php?products_id=8905
The pic is the 18f4550.
Anyone as an example with ccs?
robomaniac
PostPosted: Fri Jul 17, 2009 6:29 am     Reply with quote
Created a PWM output
Connect that output to the PWMA and PWMB
Then you will to have 4 more output to control the direction of the motor.
So connect some IO to BIN1,BIN2, AN1 and AN2.
When
BIN1 = 0
BIN2 =1 motor will trun in one direction
BIN1 = 1
BIN2 = 0 motor will trun the other direction
The speed will be control with PWMB.
Look in the CCS manual page 236 of manual
http://www.ccsinfo.com/downloads/ccs_c_manual.pdf
or page 248 of pdf.
Look at the example file to have the code.
Have fun
Jérôme Demers
www.jeromedemers.com
ricard0g0mes
PostPosted: Fri Jul 17, 2009 7:48 am     Reply with quote
but i want to control 2 motor's with different velocity's
robomaniac
PostPosted: Fri Jul 17, 2009 7:55 am     Reply with quote
yes that is why you have PWMA and PWMB on your chip.
Depending of your PIC, you can have 2 PWM on the PIC
CCP1 and CCP2
I use 18F4580 for my robot sumo and I have 2 PWM.
Check the datasheet of your pic and see if you have 2 PWM on it.
Fisrt thing you must do, it dim a LED with CCP1. After you will create a other PWM. When that is done the rest is easy.
Jérôme Demers
