Problem with compiling with PCW C on Vista
Jag
PostPosted: Sun Feb 08, 2009 9:28 pm     Reply with quote
I have used PCC compiler for PIC16F877A with no problems on windows XP. However, when I transfered this compiler to Vista and tried to compile the same project, I got the following error:
Error[300] D:\Myproject\main.c 356: More infor: File access denied
Error[44] D:\Myproject\main.c 356: Internal Error = Contact CCS OUTPUT FILE O
Does anyone have a clue as to how I can work around this? All the files in the project are read/write.
_olaf_
PostPosted: Mon Feb 09, 2009 1:25 am     Reply with quote
did you set the access rights for the files and folders on the Vista PC? Is the file access for the Vista user active?
This was my problem. I had to set the rights for the project/files/folders for the Vista user.
Regards, Olaf
Jag
PostPosted: Mon Feb 09, 2009 8:15 am     Reply with quote
Thanks Olaf...that did it. It works now!!!
RossJ
PostPosted: Thu Jul 16, 2009 1:20 am     Reply with quote
Hello all,
I have just installed PCWH 4.094 and am experiencing Vista security problems. I'm not sure why this is just starting now as I have previously had other versions working fine (including 4.093).
I get a similar error to the one mentioned earlier in this thread except mine is for 'OUTPUT FILE M' (not 'O').
I have messed about with the Vista permissions but can't find any higher level of permissions to assign. I am also not sure which file/directory PCW is actually having a problem with since it doesn't tell me. I assume the project directory, but have also looked at the C:\Users\Ross\AppData\Roaming\PICC directory.
The only way I can currently make PCW work is to set PCW.exe to run as administrator (compatibility options), which is not ideal.
Any help would be greatly appreciated.
/Ross.
RossJ
PostPosted: Thu Jul 16, 2009 8:37 pm     Reply with quote
Hi again,
CCS have just release 4.095 with a noted fix for Vista. My problem is resolved with this new release.
/Ross.
