help with using other debugger tools
PostPosted: Tue Jul 14, 2009 1:55 pm     Reply with quote
How do you use a Microchip debugging tool (real ice, icd 2, etc) with CCS? I found the page on CCS's FAQ and I have downloaded and installed the plugin but I am lost on what to do after that point.
I do have MPLAB installed, version 8.3.
My CCS version is 4.082
bkamen
PostPosted: Tue Jul 14, 2009 2:01 pm     Reply with quote
You operate the compiler in commandline mode from the MPLAB environment...
Then make sure to add
#device ICD=TRUE
(and possibly the #fuse DEBUG, but I never use it and it works fine)
and then use the DEBUGGER selected to ICD2.
This is my normal running environment.
MPLAB w/PCWHD and ICD2 and ICD3
Cheers,
-Ben
PostPosted: Tue Jul 14, 2009 2:02 pm     Reply with quote
oh so you have to run it within MPLAB
bkamen
PostPosted: Tue Jul 14, 2009 2:04 pm     Reply with quote
Didn't I mention that at the top of my reply?
Hahahah...
:D
Cheers,
-Ben
PostPosted: Tue Jul 14, 2009 2:20 pm     Reply with quote
This thread has detailed instructions for using ICD2 in MPLAB with CCS.
It tells how to step through code and to use a Watch window for variables:
http://www.ccsinfo.com/forum/viewtopic.php?t=23151
That's for MPLAB and the CCS command line compilers.
Do you want to use the ICD2 from within the CCS IDE ?
If so, see this FAQ article:
http://www.ccsinfo.com/faq.php?page=icd2_real_ice
bkamen
PostPosted: Tue Jul 14, 2009 2:24 pm     Reply with quote
Good Links.
Honestly, I never had a problem like so many have seemed to running MPLAB w/CCS and a PICstartPLUS (not a debugger, I know), PICkit2, ICD2 or (now ICD3).
Just read through the docs and learn the environment (and find the bugs! ahhaha) and everything works fine.
-Ben
