mutthunaveen
Joined: 08 Apr 2009 Posts: 100 Location: Chennai, India
why this method did not work " if(a||b||c||d) |
Posted: Mon Jul 13, 2009 12:28 am |
hi every one
I programmed a logic which uses 4 input pins
int a, b, c, d;
a=input(pin_b1);
b=input(pin_b2);
c=input(pin_b3);
d=input(pin_b4);
if (a||b||c||d) output_high(pin_a1); |
This is the code I programmed but this does not work.
When I changed the above code like this it works:
Code: | if (a==1||b==1||c==1||d==1) output_high(pin_a1); |
It works....... I don't know why it did not work... did I make any mistake or any compiler issue?
But this also works:
Code: | if (a&&b&&c&&d) output_high(pin_a1); |
Summary: AND logic works but OR logic don't work.
Anyone reveal me please.
Posted: Mon Jul 13, 2009 1:12 am |
Compiling your code under PCH 4.093 for the PIC18F86J16 produces the following:
.................... int a, b, c, d;
.................... a=input(pin_b1);
00022: BSF F93.1
00024: CLRF 06
00026: BTFSC F81.1
00028: INCF 06,F
.................... b=input(pin_b2);
0002A: BSF F93.2
0002C: CLRF 07
0002E: BTFSC F81.2
00030: INCF 07,F
.................... c=input(pin_b3);
00032: BSF F93.3
00034: CLRF 08
00036: BTFSC F81.3
00038: INCF 08,F
.................... d=input(pin_b4);
0003A: BSF F93.4
0003C: CLRF 09
0003E: BTFSC F81.4
00040: INCF 09,F
.................... if (a||b||c||d)
00042: MOVF 06,F
00044: BNZ 0052
00046: MOVF 07,F
00048: BNZ 0052
0004A: MOVF 08,F
0004C: BNZ 0052
0004E: MOVF 09,F
00050: BZ 0056
.................... output_high(pin_a1);
00052: BCF F92.1
00054: BSF F89.1
.................... if (a&&b&&c&&d)
00056: MOVF 06,F
00058: BZ 006A
0005A: MOVF 07,F
0005C: BZ 006A
0005E: MOVF 08,F
00060: BZ 006A
00062: MOVF 09,F
00064: BZ 006A
00066: BCF F92.1
00068: BSF F89.1
I haven't tried running it, but I don't see anything wrong with the assembly code. Are you using the latest compiler version? I have seen problems with logic similar to yours in older versions (but not for quite some time). When you say it doesn't work, what are you actually observing?
/Ross. |
mutthunaveen
thanks bro |
Posted: Mon Jul 13, 2009 10:24 pm |
ill check my compiler version and ill update to u
actually i coded for 4 pins in the port B with tris function
a=input(pin_b1);
b=input(pin_b2);
c=input(pin_b3);
d=input(pin_b4);
when i used a logic as if(a||b||c||d) { output_high(pin_a1); }
but if i enable these 4 pins to 1, the a1 pin is not going to 1
i changed the code to if(a==1||b==1||c==1||d==1) {output_high(pin_a1); }
then when i enable the put pins then the output pin a1 is going high.....
so here it is working |
RossJ
Posted: Mon Jul 13, 2009 10:35 pm |
I see no reason why your two if statements shoul behave any differently to each other. The only way to confirm if it is a compiler issue is to look at the generated assembly code (in the .LST file). Can you post the 'relevant' part of the .LST file as I did previously.
/Ross. |
mutthunaveen
Posted: Tue Jul 14, 2009 1:14 am |
my compiler is installed in other PC.... ill go home evening.
ill update the ASM code today evening........
thanks for ur interest |
FvM
Posted: Tue Jul 14, 2009 1:22 am |
Quote: | but if i enable these 4 pins to 1, the a1 pin is not going to 1 |
What does "enable to 1" exactly mean? |
mutthunaveen
Posted: Tue Jul 14, 2009 2:28 am |
FvM wrote: | Quote: | but if i enable these 4 pins to 1, the a1 pin is not going to 1 |
enable 1 means... i made particular pin to "high" +4.5V
so if i give high for those pin i configured the pin a1 must be high |
FvM
Posted: Tue Jul 14, 2009 7:12 am |
Quote: | so if i give high for those pin i configured the pin a1 must be high | I agree. In this case, can you post a complete application, that produces the problem, including #fuses and processor type selection, and tell the actual compiler version. |
mutthunaveen
Posted: Tue Jul 14, 2009 9:08 am |
So this is my entire code for program
#include <16F88.h>
#use delay(clock=14000000)
#use fast_io(b)
#use fast_io(a)
void main(){
while(1){
int a, b, c, d;
set_tris_a(0x00);
set_tris_b(0x0F);
a=input(pin_b0);
b=input(pin_b1);
c=input(pin_b2);
d=input(pin_b3);
if (a&&b&&c&&d) output_high(pin_a2);
The ASM code is
CCS PCM C Compiler, Version 4.023, 25097 14-Jul-09 20:23
Filename: C:\Program Files\PICC\Examples\EX_GLCD.lst
ROM used: 60 words (1%)
Largest free fragment is 2048
RAM used: 6 (2%) at main() level
10 (3%) worst case
Stack: 0 locations
0000: MOVLW 00
0001: MOVWF 0A
0002: GOTO 004
0003: NOP
.................... #include <16F88.h>
.................... //////// Standard Header file for the PIC16F88 device ////////////////
.................... #device PIC16F88
.................... #list
.................... #fuses HS,NOWDT,NOPROTECT,NOLVP
.................... #use delay(clock=14000000)
.................... #use fast_io(b)
.................... #use fast_io(a)
.................... void main(){
0004: CLRF 04
0005: BCF 03.7
0006: MOVLW 1F
0007: ANDWF 03,F
0008: BSF 03.5
0009: BCF 1F.4
000A: BCF 1F.5
000B: MOVF 1B,W
000C: ANDLW 80
000D: MOVWF 1B
000E: MOVLW 07
000F: MOVWF 1C
.................... while(1){
.................... set_tris_a(0x00);
0010: MOVLW 00
0011: MOVWF 05
.................... set_tris_b(0x0F);
0012: MOVLW 0F
0013: MOVWF 06
.................... a=input(pin_b0);
0014: BCF 03.5
0015: CLRF 21
0016: BTFSC 06.0
0017: INCF 21,F
.................... b=input(pin_b1);
0018: CLRF 22
0019: BTFSC 06.1
001A: INCF 22,F
.................... c=input(pin_b2);
001B: CLRF 23
001C: BTFSC 06.2
001D: INCF 23,F
.................... d=input(pin_b3);
001E: CLRF 24
001F: BTFSC 06.3
0020: INCF 24,F
.................... if (a||b||c||d) output_high(pin_a1);
0021: MOVF 21,F
0022: BTFSS 03.2
0023: GOTO 02C
0024: MOVF 22,F
0025: BTFSS 03.2
0026: GOTO 02C
0027: MOVF 23,F
0028: BTFSS 03.2
0029: GOTO 02C
002A: MOVF 24,F
002B: BTFSS 03.2
002C: BSF 05.1
.................... if (a&&b&&c&&d) output_high(pin_a2);
002D: MOVF 21,F
002E: BTFSC 03.2
002F: GOTO 039
0030: MOVF 22,F
0031: BTFSC 03.2
0032: GOTO 039
0033: MOVF 23,F
0034: BTFSC 03.2
0035: GOTO 039
0036: MOVF 24,F
0037: BTFSS 03.2
0038: BSF 05.2
0039: BSF 03.5
003A: GOTO 010
003B: SLEEP
Configuration Fuses:
Word 1: 3F62 HS NOWDT PUT MCLR BROWNOUT NOLVP NOCPD NOWRT NODEBUG CCPB0 NOPROTECT
Word 2: 3FFF FCMEN IESO |
Posted: Tue Jul 14, 2009 1:39 pm |
1. How are you testing this program ? Are you using a simulator ?
If so, which one ? Or is it a hardware board ? If so, have you ever
made this board do anything, such as blinking an LED ?
2. Describe the external circuits on pins B0 to B3.
3. Is this frequency value accurate ? 14 MHz is an unusual frequency:
Quote: | #use delay(clock=14000000) |
bkamen
Posted: Tue Jul 14, 2009 1:59 pm |
I think it's a little easier to some extent than this..
|| is a COMPARATIVE 'OR' requiring a complete expression output OR'd with another. ANY of those expressions being true controls the conditional.
where | is a logical 'OR' and the result of the OR controls the conditional.
If you have several single bit values (easier to work with), you can LOGICALLY 'OR' them together and that would work.
So
If A = 1 and B = 0
A | B == 1
So you COULD write (and I've done this)
if (a|b) { // A|B is non-zero
do something
or
if ( ! (a|b) ) { // A|B is zero
do something
OR (no pun)
if ( (a|b) == 0 ) { // A|B is zero
do something
Cheers,
Ben _________________ Dazed and confused? I don't think so. Just "plain lost" will do. :D |
mutthunaveen
Posted: Wed Jul 15, 2009 2:21 am |
So
If A = 1 and B = 0
A | B == 1
thanks bro
I'll try this today.........evening
and IO am using a PIC simulator oshonsofts latest trial version. |
FvM
Posted: Wed Jul 15, 2009 7:54 am |
I just want to report, that the example application is operating correctly with PCM V4,093 and MPLAB SIM, thus I don't expect that there is a real issue with the code. I'm under the impression, that the shown V4.023 code is also correct, particularly the questioned "if (a||b ...)" line.
As a general remark, if rather outdated CCS C versions or third party simulators are involved with any assumed bugs, I would like this clearly mentioned from the start. |
bkamen
Posted: Wed Jul 15, 2009 8:30 am |
FvM wrote: | I just want to report, that the example application is operating correctly with PCM V4,093 and MPLAB SIM, thus I don't expect that there is a real issue with the code. I'm under the impression, that the shown V4.023 code is also correct, particularly the questioned "if (a||b ...)" line.
I would expect A||B to work - but the user must understand that it really means
A != 0 (positive integer)
B != 0 (positive integer)
A or B could be > 1. If this is ok, then A||B is ok.
(Maybe some would say it's bad form? I tend to spell out my stuff so it's not cryptic to the next potential coder.)
Anyway - I had forgotten to mention that, so cheers.
