btfsc instruction converted in CCS C
horde_fuego
PostPosted: Sun Jul 12, 2009 9:32 pm     Reply with quote
good morning everyone!!
how do i write a code in CCS which performs the same routine that the btfsc (assembly language instruction in MICROCHIP) does?
thanks!! Very Happy Very Happy Very Happy
bungee-
Re: btfsc instruction converted in CCS C
PostPosted: Sun Jul 12, 2009 11:19 pm     Reply with quote
#asm
btfsc ....
#endasm
Rolling Eyes
PostPosted: Sun Jul 12, 2009 11:43 pm     Reply with quote
You can generate that ASM instruction by calling the bit_test() function,
as shown below. Look at the .LST file.
#include <16F877.H>
int8 value;
int8 result;
value = 0x55;
if(bit_test(value, 7) == 0)
   result = 0;
   result = 1;
There is probably a CCS function for most things that you want to do.
Look at the list of Bit Manipulation functions on this page:
http://www.ccsinfo.com/content.php?page=compspecific#bit
Then look in the CCS manual or the Help File for more information.
horde_fuego
PostPosted: Mon Jul 13, 2009 2:14 am     Reply with quote
To bungee and PCM programmer,
Thank you very much for the replies. This will surely help me in my program. Thanks a lot!!
Very Happy Very Happy Very Happy Very Happy
-horde
RLScott
PostPosted: Mon Jul 13, 2009 6:25 am     Reply with quote
horde_fuego wrote:
...how do i write a code in CCS which performs the same routine that the btfsc ...
Often the "if(bit_test(x,y))" will compile to a single btfsc or btfss instruction.
Robert Scott
Real-Time Specialties
Embedded Systems Consulting
