kender
Strange reset behavior. PIC doesn’t start. |
Posted: Wed Jun 10, 2009 3:51 pm |
Colleagues,
I have a PIC18F4620 that refuses to start when the power is turned off and then re-applied. Vcc has a fair amount of capacitance and the voltage stays between 0.4V and 0.6V for some time. The problem is that if Vcc goes back to +5V, the PIC doesn’t start. If MCLR# is toggled, the PIC starts and operates normally. MCLR# has 47k pull-up.
A bleed resistor could be added between Vcc and ground, but I don’t want to add it because my device is battery powered. I have a brownout detection enabled, but something’s wrong.
Any suggestions or insights would be appreciated.
Code: | #include <18F4620.h>
#device ICD=TRUE
#device adc=8
// #FUSES WDT128 //Watch Dog Timer uses 1:128 Postscale
#FUSES BROWNOUT
#FUSES BORV43 //Brownout reset at 4.6V (highest brownout threshold)
#FUSES NOLVP //Low Voltage Programming on B3(PIC16) or B5(PIC18)
#FUSES NOEBTR //Memory not protected 8from table reads
#FUSES PBADEN //PORTB pins are configured as analog input channels on RESET
setup_oscillator(OSC_8MHZ); |
PIC18F4620, Vcc=+5V, MCLR# has a 47k pull-up
PCWH 4.081
Cheers,
- Nick _________________ Read the label, before opening a can of worms. |
Posted: Wed Jun 10, 2009 3:57 pm |
and then re-applied |
Post what you mean by "refuses to start". How far into the program
does it go ? How can you tell ?
Post your main(). Ideally, it should just consist of a LED blinking loop,
for this test. Also, disconnect all external user application circuits except
the LED and its series resistor.
Post if you are running this as a standalone program, or if you are
running it in debug mode.
Is the debugger/programmer plugged into the board ? Which one
are you using ? (ICD-U40, ICD2, etc.) |
Posted: Thu Jun 11, 2009 3:35 am |
Two other comments.
Use PUT, rather than NOPUT. If the supply rail rises slowly, there can be problems with the oscillator refusing to start. PUT will help in this case.
Consider adding a diode, resistor and small capacitor to the MCLR pin. If you pull the data sheet for the 18F452, and look at the section for 'reset', this shows the circuit you should use (it is illustrated in several other PIC data sheets as well). Basically, what you do, is have a small capacitor (0.01uF say), connected at one end to 0v, and the other end via a resistor to the MCLR pin (use perhaps 150R). This capacitor then has the pull up (perhaps 22KR), and a diode, to discharge it quickly when the power rail falls. This is the recommended reset circuit, if the supply takes more than a few uSec to rise to 5v. It sounds as if you have a lot of capacitance on your supply, and as such you should consider this.
nostep
Posted: Thu Jun 11, 2009 4:35 am |
What's connected to your outputs, anything? I've seen external devices hold up the processor from starting properly if they are powered and the power finds its way back to some processor pins. As suggested, the PUT timer should help. |
kender
Posted: Thu Jul 09, 2009 12:48 am |
Fixed this problem by adding an external reset supervisor MAX809. _________________ Read the label, before opening a can of worms. |
Posted: Sat Jul 11, 2009 7:37 am |
so basically U R saying
it WAS the lack of hardware management
of the MCLR pin - that was your problem? |
kender
Posted: Sat Jul 11, 2009 11:43 am |
Anonymous wrote: | so basically U R saying
Back then, I ran out of time and resorted to a "paint over" approach. I didn't do all of the necessary diagnostic steps to find the root cause of the problem. _________________ Read the label, before opening a can of worms. |
bkamen
Posted: Sun Jul 12, 2009 2:44 pm |
Whoa whoa...
If you have ICD=TRUE, I don't think the pic will normally just run (depending on environment settings)
If you don't have the debugger hooked up and then enable the firmware to go.. You shouldn't be programming with ICD=TRUE.
When you want the system to be autonomous, you have to comment out the ICD=TRUE and then recompile and program.
Otherwise, when I use ICD mode, I'm always at the helm anyway.
So maybe this helps?
Cheers,
-Ben
BTW, I'm using a project now with an 18F4620 and it works just fine with ICD=TRUE, PROVIDED I'm ACTUALLY debugging. Otherwise I comment out ICD=TRUE for a more "production" build. _________________ Dazed and confused? I don't think so. Just "plain lost" will do. :D |
