RGB LED DRIVER
IceMetal
RGB LED DRIVER
PostPosted: Fri Jul 10, 2009 1:54 pm     Reply with quote
Hi guys I'm trying control an RGB led driver, the led driver has 2 inputs that I'm using, the clock the for every pulse selects the led and the SDI that everytime is high will light up the LED
The driver can control 8 RGB leds( 24 LEDS) so after 24 clock pulses it goes back to the begining of the led.
in between thouse pulses I have to set the SDI high to light up the LEDs I want, so I was thinking to send a command like R00011000 to lit up the 2 middle red LEDs, or B00011000 to lit up the 2 middle blue leds, how can I send 2 package of data like to select the color and the location of the LED.
Thank you guys.
#include <16F887.h>
#FUSES NOWDT
#FUSES NOMCLR
#FUSES NOCPD
#FUSES NOBROWNOUT
#FUSES XT
#define SDI     PIN_D0
#define CLK     PIN_D1
int i, data;
counting()
output_low(SDI);
for (i=0; i<data; ++i){
output_low(CLK);
output_high(CLK);
printf("%2x", data);
Main() {
output_high(SDI);
output_high(CLK);
output_low(CLK);
while(1){
if(kbhit())
             data=getc();
counting();
PostPosted: Fri Jul 10, 2009 1:59 pm     Reply with quote
Post the manufacturer and part number of this chip.
IceMetal
PostPosted: Fri Jul 10, 2009 2:08 pm     Reply with quote
sure its the STP24DP05
http://www.st.com/stonline/products/literature/ds/14714.pdf
