Write_EEPROM and RDA interrupt conflict.
Cam Bruce
PostPosted: Mon Jan 24, 2005 2:19 pm     Reply with quote
My problem is an unexplainable disabling of the serial interrupt.
Using a 18F452, PCH 3.152
I have a host computer polling one register in EEPROM. The PIC receives this poll, and replies with the register value. The register value changes, repending on an Input Logic level. I think that I hit a snag, when the poll ocurrs as the input pin changes state.
At that time, I no longer get the serial interrupt.
I added LEDs to the code, so I could see. The program enters, and leaves the ISR, but, once a conflict ocurrs, the serial interrupt is disabled.
The attached code still conflicts. I have thinned it out, to try to find the problem.
Any thoughts ?
Cam
////                          TMB_452-13Jan05.C                          ////
////   Thinned out, to find why Serial Interrupt is being Disabled.   ////
#include "18F452.H"
////   Definitions         ////
#DEFINE DIGIN1 PIN_D1      //PIN FOR DIGITAL INPUT 1
#DEFINE FULL_RESET PIN_B1   //RESET RELAY, OUTPUT PIN
#use standard_io(C)
#DEFINE DIG_MASK 0XF4   //DIGITAL ALARM DISABLE MASK
short   check_alarm=0;      //used to set how long between alarm checks.
INT   DIG_AMIOK;            //BIT BY BIT (FOR 6 BITS) DIGITAL "AM I OK?"
INT   LAST_DIG=0xFF;         //THIS IS THE LAST ALARMS I HAD.
long   silent_time;      //used for a "long idle time" reset.
long   int_count=0;         // Number of interrupts left before a second has elapsed
int   SECONDS=0;            //a running real time counter.  starts at 0 on reset, counts forever.
short from_host=0;         //set in Serial ISR, while Host is sending
int   byte_count=0;         //counter for received numbers
int   RMC_data_in[8];         //Array for data received from Host.
#byte porta=5         //These lines define the Ports.
#byte portb=6
#byte portc=7
#byte portd=8
#byte porte=9
////   End of Definitions   ////
#fuses HS,NOPROTECT,NOWDT,PUT,NOLVP   //WDT disabled for testing, NEEDS re-enabled
#use delay(clock=4000000)      //USING A 4MHz CRYSTAL
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, parity=n)
////   THE NEXT LINES ARE THE Rx Data INTERRUPT ROUTINE.   ////
#int_rda
VOID serial_isr()
   if(kbhit())               //is there a serial byte ready ?
      output_high(pin_d5);            //turn on a LED for testing
      RMC_data_in[byte_count]=getc();   //save data to the array
      Silent_Time=0;               //reset silent time counter
      if(++byte_count>=6)            //ARRAY NOW HAS THE 6 BYTE MODBUS COMMAND (use >=, to catch a runaway)
         {byte_count=0;            // Buffer full, RESET IT
         from_host=1;            //set flag, to check the string
         }//end if byte_count==6
      output_low(pin_d5);            //turn off the LED
////   END OF INTERRUPT SERVICE ROUTINE      ////
VOID main()                //
output_low(full_reset);         //don't do it.....
int_count=1;         //Initialize to roll over next time through.
set_timer0(0);
setup_timer_0( RTCC_INTERNAL|rtcc_8_bit|rtcc_div_2);
SETUP_WDT(WDT_OFF);               //DISABLED FOR TESTING
ENABLE_INTERRUPTS(INT_RDA);         //RDA (Serial Receive Data).
enable_interrupts(global);
DO
if(--int_count==0)         //has one second gone by ?
   if(++SECONDS==60)      //start again after one minute.
      SECONDS=0;
   int_count=10000;         //Trial and error, 500-low,1000-low,5000-low,10000
   CHECK_ALARM=1;         //check alarms every second
   }//end of --int count==0
if(check_alarm)      //has one second gone by?
   {////   Check the Digital Input Pin.
   DIG_AMIOK=0xFF;         //INITIALISE, ASSUMING NO ALARMS
   IF(!INPUT(DIGIN1))            //CLECK EACH DIGITAL INPUT, ONE AT A TIME.
      BIT_CLEAR(DIG_AMIOK,1);            //This is for real, CLEAR THE ALARM BIT.
   Else BIT_SET(DIG_AMIOK,1);      //No alarm on input 1.
   Check_Alarm=0;   //reset flag
   }//end of check_alarm
if((dig_amiok!=LAST_DIG))   //check for change of state in alarms
   Write_EEPROM(0XD8,DIG_AMIOK);            //FORCE A SAVE
   LAST_DIG=DIG_AMIOK;
if(from_host)   //from_host is a flag, set in the serial interrupt routine.
            //by now, the array RMC_Data_In[] holds the 6 byte ModBus string.
   output_high(pin_d6);      //turn on a LED for testing
   if(RMC_data_in[1]==3)      //is this a "Read Register Function"?
      if(RMC_data_in[2]==0)   //"TRUE" EEPROM Area
         putc(0x55);            //repeat site address
         putc(0x03);            //repeat command (0x03)
         putc(0x02);            //number of bytes to follow
         putc(0x00);            //Low Byte Filler
         putc(read_eeprom(RMC_Data_In[3]));   //actual data from eeprom.
         }//End of TRUE EEPROM Reads
      }//End of all "READS"
   output_low(pin_d6);            //turn off the LED
   from_host=0;            //re-set flag.
   }//END OF IF FROM_HOST...
////   not much happening...
   if(++silent_time>1000)            //count, while waiting for another Serial Byte
      silent_time=0;               //reset silent serial time timer
      byte_count=0;               //reset byte counter.  Clears a Runt.
      }//end of silent_time>1000
}WHILE (TRUE);            //"DO" IT ALL AGAIN.
}               //end of Main.
PostPosted: Mon Jan 24, 2005 2:34 pm     Reply with quote
Without examining your code in detail, I can think of a number
of reasons for this:
1. You could be getting several incoming characters in a short time.
The eeprom write takes several milliseconds. You're not servicing
the interrupt during that time, so an overrun occurs. You don't
have the ERRORS directive in your #use rs232 statement, so the
USART receiver locks up.
2. In some versions of the compiler, CCS didn't handle disabling/
enabling interrupts properly during writes to eeprom.
Nandus2000
PostPosted: Wed Jul 08, 2009 4:54 am     Reply with quote
I've used #use rs232 statement in my code.
But still I've similar issue because I'm not able to serve RS232 RDA interrupt as program is busy in write_eeprom library function.
I'm using Compiler: CCS version 4.076.
Does anybody know that this conflict has been resolved in the latest version 4.093 at the moment?
Awating your prompt reply.
Thanks!!
