usb example project
bharatwalia
usb example project
PostPosted: Thu Jun 25, 2009 2:25 pm     Reply with quote
Hi, I got a "PIC18f2550" IC can anybody get me some usb example projects so that I am able to interface my PC with the PIC.
PostPosted: Thu Jun 25, 2009 2:37 pm     Reply with quote
Do you own the CCS compiler ? Look in the Examples directory.
It has all these USB examples:
c:\program files\picc\examples\ex_usb_hid.c
c:\program files\picc\examples\ex_usb_scope.c
c:\program files\picc\examples\ex_usb_mouse.c
c:\program files\picc\examples\ex_usb_kbmouse2.c
c:\program files\picc\examples\ex_usb_kbmouse.c
c:\program files\picc\examples\ex_usb_serial2.c
c:\program files\picc\examples\ex_usb_serial.c
c:\program files\picc\examples\ex_usb_bootloader.c
c:\program files\picc\examples\ex_usb_loadmouse.c
bharatwalia
PostPosted: Thu Jun 25, 2009 2:50 pm     Reply with quote
yes , i own a ccs compiler.But i need some PC side examples like in VC++ or in VB
PostPosted: Thu Jun 25, 2009 3:09 pm     Reply with quote
Look in the Code Library forum.
This is a 2-page thread which uses Microsoft .net tools to create the
PC-side USB Windows application:
http://www.ccsinfo.com/forum/viewtopic.php?t=24207
If you have current compiler maintenance with CCS, then you can
download the USB development kit files. There's a button for it in
the lower right corner of this page:
http://www.ccsinfo.com/compilerupdates.php
It has sample Windows applications written in Delphi. These are an
"Oscope" application and an "HidDemo" application.
xuxa
sample code
PostPosted: Tue Jul 07, 2009 8:30 pm     Reply with quote
I tried to use the
in CCS compiler.
What changes do I have to do in the code, or wich header codes and sources codes do I have to add to compile the project?
I would like to use this to make a keybord interface to a LCD display, so any character pressed in keyboard is shown on LCD.
Im from Brazil, my english is not good, thanks
