PIC24F no division possible?
richi-d
PostPosted: Sun Jul 05, 2009 8:45 am     Reply with quote
I use PCD 4.089 and MPLAB 8.33.
I have this program and the Division doesn't work - Why? The variable Rechendummy1 has the value: -1.27393755e-018
Rechendummy2 has the value: -4.20128342e-019
WEG_PRO_ZEIT has the value: 3.28758075e-019
After one run? Why does Rechendummy1+2 not have the values I give them?
MAIN:
#include <24FJ128GA106.h>
//#device adc=10
#include <string.h>
#include <math.h>
#include <Main_V01.h>
   WEGDIFFERENZ = 376;
   ZEITDIFFERENZ = 31;
   for(;;)
      RECHENDUMMY_1 = WEGDIFFERENZ;
      RECHENDUMMY_2 = ZEITDIFFERENZ;
      WEG_PRO_ZEIT = RECHENDUMMY_1 / RECHENDUMMY_2;
      }//   for(;;)
   }//Main()
MAIN_V01.H:
#FUSES FRC_PLL,NOPROTECT,NOIESO,NOJTAG,ICSP1,DEBUG
#use delay (clock=32000000)
float         RECHENDUMMY_1;
unsigned int   WEGDIFFERENZ;
float         RECHENDUMMY_2;
unsigned int   ZEITDIFFERENZ;
float         WEG_PRO_ZEIT;
PostPosted: Sun Jul 05, 2009 9:35 am     Reply with quote
You don't actually show 'main.h', being included anywhere. Presumably main_v01....
What are you using to 'see' the values?.
richi-d
PostPosted: Sun Jul 05, 2009 11:07 am     Reply with quote
I edited the error.
I use the MPLAB IDE Watch window.
FvM
PostPosted: Sun Jul 05, 2009 3:39 pm     Reply with quote
You must select IEEE float format in watch window to see meaningful values.
richi-d
PostPosted: Mon Jul 06, 2009 12:54 am     Reply with quote
I tested all formats - no change! I´m wondering why this lines doesn´t work:
Is there any other adjustments I need to do?
PostPosted: Mon Jul 06, 2009 2:22 am     Reply with quote
First, I'd prove where the problem is.
If you have a serial link available, simply try printing the result to this. If you haven't, use sprintf, to print the value to a character buffer, and look at this with MPLAB. You can also look at the .sym file, and verify that the address given for the variables, is the address being selected by MPLAB.
The behaviour has all the symptoms of the debugger, either not looking at the right bytes, or using the wrong format for the numbers.
You can also again use the .sym data, and record what the four bytes actually at the location for each variable are.
Remember the default 'float' is a 32bit float for CCS.
FvM
PostPosted: Mon Jul 06, 2009 4:50 am     Reply with quote
At least with PCD V4.093, the values are prefectly converted to float. I guess, it's O.K. with your version as well. But you have to select IEEE float format for each individual float variable in the watch window, as said. Of course, printf() works as well, I wonder, why you didn't try before posting in the forum?
richi-d
PostPosted: Mon Jul 06, 2009 5:18 am     Reply with quote
I use the IEEE float format!!! But it still don´t show the values correct!
But I used my display now to show the values, and this works. But this is bad for debugging...
WEGDIFFERENZ = 381;
ZEITDIFFERENZ = 31;
         WERT = RECHENDUMMY_1;
         GetDigits();
         Zahl_6x8_schreiben (THOUS,49,8);
         Zahl_6x8_schreiben (HUNS,56,8);
         Zahl_6x8_schreiben (TENS,63,8);
         Zahl_6x8_schreiben (UNITS,70,8);
         delay_ms(250);
         WERT = RECHENDUMMY_2;
         GetDigits();
         Zahl_6x8_schreiben (THOUS,49,20);
         Zahl_6x8_schreiben (HUNS,56,20);
         Zahl_6x8_schreiben (TENS,63,20);
         Zahl_6x8_schreiben (UNITS,70,20);
         delay_ms(250);
         WERT = WEG_PRO_ZEIT;
         GetDigits();
         Zahl_6x8_schreiben (THOUS,49,30);
         Zahl_6x8_schreiben (HUNS,56,30);
         Zahl_6x8_schreiben (TENS,63,30);
         Zahl_6x8_schreiben (UNITS,70,30);
         delay_ms(250);
PostPosted: Mon Jul 06, 2009 6:36 am     Reply with quote
If you had done what I said, and looked directly at the four bytes involved, rather than posting more (totally useless) code, you or we, could have seen what was going on....
Forget about division. The value in RECHENDUMMY_1, should be the byte sequence for an IEEE float32 variable, holding '376', no division involved. This is Hex 43BC0000. The value you are giving '-1.27393755e-018 ', is the value displayed using CCS float format, for the Hex byte sequence 0000BC43. Note the reverse order.
You still have got CCS format selected, and you have the byte order set reversed somewhere (MPLAB allows you to specify this)...
FvM
PostPosted: Mon Jul 06, 2009 10:26 am     Reply with quote
It may be the case, that MPLAB behaviour has changed regarding float diisplay. Actually, PCD uses a reversed IEEE float format with the exponent byte at the lowest address. It's correctly displayed by MPLAB V8.20 by simply selecting "IEEE float" format. The byte reverse option isn't provided with this format in V8.20.
