18F2520 Timer Setup Problem
Goto page 1, 2  Next
R0B0T1CS
PostPosted: Sun Jul 05, 2009 2:42 pm     Reply with quote
I usually use the 18F452, but today it's the 18F2520.
Even with the oscillator disconnected, the output pin provides a 59% duty cycle 136us period square wave. If the pin address is changed the outputs do change to the new pin. If the delay is increased the output does not change, thought dropping it drastically, from 70ms to70 us, does increase the period by about 10%.
Perhaps I must disable the internal osc?
Here's some of the code.
Thanks for any help.
Do you perhaps know of example code using the 18F2520 and an external osc?
#include "18F2520.h"
#device icd=true
#device *=16 ADC=8
#fuses HS,NOPROTECT,NOLVP,NOWDT,PUT,NOBROWNOUT
#use delay(clock=40000000) //(40Mhz)
#include <stdio.h>
#include <string.h>
output_low(Pin_A0);
delay_ms(70);
output_high(Pin_A0);
delay_ms(70);
PostPosted: Sun Jul 05, 2009 3:04 pm     Reply with quote
The oscillator pin is probably just floating, and generating some random speed connected to some external signal.
_HS_, does not support 40MHz. The maximum _oscillator_ supported by the chip, is 25MHz. To go above 25MHz, you need to use a lower frequency crystall, and the PLL, or an external oscillator module.
PostPosted: Sun Jul 05, 2009 3:08 pm     Reply with quote
Do you have a 10 MHz crystal (and associated capacitors) connected to
the oscillator pins of the PIC ? If so, the "H4" fuse cause the PIC to run
at 40 MHz. Example:
#include <18F2520.h>
#fuses H4,NOPROTECT,NOLVP,NOWDT,PUT,NOBROWNOUT
   output_low(PIN_A0);
   delay_ms(70);
   output_high(PIN_A0);
   delay_ms(70);
R0B0T1CS
PostPosted: Sun Jul 05, 2009 3:55 pm     Reply with quote
Using a 20MHz crystal, instead of the 40MHZ Oscillator, doesn't improve anything. Produces signal is now 7us instead of 80us.
Actually, if I have NO Osc or TX connected, it still has the same timing. Something Internal is triggering the uC. How do I turn it off?
PostPosted: Sun Jul 05, 2009 4:10 pm     Reply with quote
How do you know this ? Are you testing this project on real hardware
with an oscilloscope ? Or is this a Proteus project ? What is your
compiler version ?
R0B0T1CS
PostPosted: Sun Jul 05, 2009 5:17 pm     Reply with quote
I'm using a scope on a real circuit.
PostPosted: Sun Jul 05, 2009 5:21 pm     Reply with quote
1. Post the test program that you are using now. Don't post code
fragments. But make it be a very small program.
2. Post if you are using an external crystal or oscillator. Post the
frequency that is written on the crystal or oscillator.
3. Post your compiler version.
R0B0T1CS
PostPosted: Sun Jul 05, 2009 7:38 pm     Reply with quote
pcwh 3.209
The PIC functions the same even when no OSC is connected.
#device icd=true
#device *=16 ADC=8
//////NOWDT,NOMCLR,INTRC_IO,NOPBADEN,NOBROWNOUT,PUT,NOLVP
#use delay(clock=20000000) //(20Mhz)
#include <stdio.h>
#include <string.h>
//SETUP_TIMER0(0)
   output_low(Pin_A0);
   delay_ms(70);
   delay_ms(70);
PostPosted: Sun Jul 05, 2009 8:08 pm     Reply with quote
You are using two different oscillator fuses. This is wrong. You should
only use one oscillator setting.
Try a simple test program and see if it works:
#fuses INTRC_IO,NOPBADEN,NOBROWNOUT,NOMCLR,PUT,NOLVP
   output_low(Pin_A0);
   delay_ms(70);
   delay_ms(70);
R0B0T1CS
PostPosted: Sun Jul 05, 2009 10:24 pm     Reply with quote
no change.
I haven't even told the program to "run" and the output is being provided. hitting "run" in the icd control gui changes nothing.
Also, if 2 osc setup statements is "wrong", then just how would you use H4 and be able to tell the uc what rate the osc*4 would be?
BTW, thanks for your help Smile
PostPosted: Sun Jul 05, 2009 10:49 pm     Reply with quote
1. What development environment are you using ? CCS IDE or MPLAB ?
2. Did you build your own board, or did you buy it ? If you bought it,
post the manufacturer and model number.
3. Have you ever made this PIC do anything successfully ?
R0B0T1CS
PostPosted: Sun Jul 05, 2009 11:21 pm     Reply with quote
wait, wait... now I see.
The second osc statement you highlighted, which I somehow missed seeing before, is extra code I missed commenting out of what I posted here.
I'm using ccs ide.
I'm building the circuit myself, but I've done this a few times before.
This is my first time using the 2520.
thanks
PostPosted: Mon Jul 06, 2009 12:51 am     Reply with quote
You have edited your post from what it was.
Do you still have a problem ? If so, post your current test program.
R0B0T1CS
PostPosted: Mon Jul 06, 2009 7:33 am     Reply with quote
If the 18F2520 is programmed and powered, whether it is being dissabled by the ICD or not, it runs the same and produces a wave form which is ~140us square wave with 59% duty cycle.
PCWH 3.209
#device icd=true
#device *=16 ADC=8
#include <stdio.h>
#include <string.h>
   output_low(Pin_A0);
   delay_ms(70);
   delay_ms(70);
It seems to me like a 2520 - specific compiler timer - configuration error.
Oooooh, a challenge :\
Thanks,
R
R0B0T1CS
PostPosted: Mon Jul 06, 2009 9:48 am     Reply with quote
Hey, I got it working Smile ... half of the time :\
Here's how to make the 18F2520 function properly at 40Mhz.
1-In the ICD interface window I used the "Advanced" tab to manually set the uC ID to 18F2520.
2-I had jumpered the internal pins in the ICD-U40 so that it would power itself and the target. So I disconnected that jumper.
3-Using your 4MHz code the timing was correct for about 2 minutes, then stopped working properly. Does not dissable when told.
-Setting to 20MHz with a 20MHz crystal it bahaves as if I'm instead connecting a 1MHz crystal. Does not dissable when told.
-Setting to 40MHz with a 40MHz oscillator briefly opperate with the proper timing, during the first test, and dissables when told via the ICD interface (run program / stop program). Note that the data sheet indicates 25MHz but the Microchip site indicates 40MHz as the max frequency.
-Setting to 1MHz with a 40MHz oscillator it opperates with the proper timing, NOW during the second test, and dissables when told via the ICD interface (run program / stop program).
Upon Power-up, there is ~50/50 chance that the 18F2520 will use proper timing or attempt to multiply the input osc frequency by 40. Cause and solution still unknown to date (07/18/09). I will post solution when found.
I have yet to test the output frequency of the CCP modules with respect to this hack (1MHz to get 40Mhz.
PCWH 3.209 must have some timer bug associated with the 18F2520. I have had trouble with other 18Fxxxx chips (newer 4 digit parts). Perhaps I should go back and try those again with the max 40MHz Osc attached instead of 10MHz & H4.
#device icd=true
#device *=16 ADC=8
#use delay(clock=1000000) //(for 40Mhz)
#include <stdio.h>
#include <string.h>
output_low(Pin_A0);
delay_ms(70);
delay_ms(70);
Thanks for your help!!!
R
Goto page 1, 2  Next
Page 1 of 2
