Expecting a ] right where the ] is!
ahinst
PostPosted: Fri Jul 03, 2009 12:24 am     Reply with quote
This beats me! If is use int8 as the decleration the Rx1Buf[Rx1BufferMask] trigers the error! However if I use byte as the decleration the Rx1Buf[Rx1BufferMask] pases OK but the Tx1Buf[Tx1BufferMask] then trigers the error!
#define Rx1BufferSize 64
#define Rx1BufferMask Rx1BufferSize-1
#define Tx1BufferSize 32;
#define Tx1BufferMask Tx1BufferSize-1
#define Tx1BufferFull Tx1BufferSize-3
// Recieve buffer
byte Rx1Buf[Rx1BufferMask];
byte R1Data;
byte Rx1Head;           //USED BY INTERRUPT
byte Rx1Tail;
byte Rx1Bcn;            //USED BY INTERRUPT
// Transmit buffer
byte Tx1Buf[Tx1BufferMask];
byte Tx1Head;
byte Tx1Tail;           //USED BY INTERRUPT
byte Tx1Bcnt;           //USED BY INTERRUPT
PostPosted: Fri Jul 03, 2009 12:32 am     Reply with quote
In the general case, don't put a semi-colon at the end of a #define
statement.
ahinst
PostPosted: Fri Jul 03, 2009 1:33 am     Reply with quote
Thanks missed that one!
