Configuration bits modification on CCS
SAMIR_SBG
PostPosted: Tue Jun 30, 2009 10:07 am     Reply with quote
I work with PIC18F14K50.
I use CCS Compiler v4.088.
There are many bugs in the compiler to set the clock frequency.
When I use the command:
#FUSES HS
#use delay (clock=20MHz)
--> I found that the really operating frequency is 5 MHz not 20MHz
When I verify with MPLab Simulator I found that:
CONFIG1L = 0x38 --> CPU Divider is set to 4
--> USB Divider is se to 2
To work with 20MHz I must use
#FUSES HS
#FUSES CPUDIV1
#fuses H4
#use delay (clock=48M, oscillator=12M)
No thing work and I found many errors in the CONFIG1L CONFIG1H
To work with 48MHz I must use
#fuses H4
#FUSES CPUDIV1
#FUSES USBDIV1
#FUSES PLLEN
But only CPUDIV1 and USBDIV1 was changed
The #FUSES PLLEN don't make any change
So I must change it directly in the end of generated HEX file:
From
:0E00000000C61E1E0008890003C003E0034076
To
:0E00000000D21E1E0008890003C003E0034076
What is the problem?
Can I change directly the configuration bits into CCS
I want to set the register CONFIG1H (Adress:0x300001) to 0xD2
Many thanks.
PostPosted: Tue Jun 30, 2009 12:52 pm     Reply with quote
You could use a #rom statement:
#rom int8 0x300001 = {0xD2}
SAMIR_SBG
PostPosted: Wed Jul 01, 2009 10:58 am     Reply with quote
Thanks "PCM programmer" you are the best Smile
