kaz
Copying by an array of pointers to const char[] doesn't work |
Posted: Tue Jun 30, 2009 9:53 am |
I think it's broken, and I'd greatly enjoy this over the alternative switch statement:
Compiler version: 4.095
Chip: PIC16F886
/*---Code example---*/
#include <stdio.h>
char *Greetings[] =
{ "Hello there.",
"Howdy.",
"Hey, you.",
"*mumble mumble*"
int main()
{ int delay = 0;
char lcd_buffer[16];
strcpy(lcd_buffer, Greetings[2]);
delay++; //At this point, lcd_buffer is filled with trash.
return 0;
I have this problem where this code compiles, but doesn't work. I tried it with a PC on gcc the other day with flying colors, not so much here. Is there a good reason for this, or another way to do it that's not a switch statement? |
Posted: Tue Jun 30, 2009 10:16 am |
Do a search on the forum, for 'pointer to constant', or look in the manual....
You can get the required effect, by simply declaring a two dimensional text array, and copying the characters from the required line, into a string as needed.
The latter compilers, do have the ability to handle this using other compilation options (ANSI), _but_ at a large cost in terms of the actual time/code size needed to support this, and only on chips that support direct reading of the code memory. The problem is that the PIC itself has an unusual memory architecture, with the 'code' memory, not directly accessible to read/write, and on some chips not available at all....
kaz
Posted: Tue Jun 30, 2009 10:48 am |
Nuts. I thought it was the same problem. I'll try the 2-dimensional array then.
Thanks for the information. |
Posted: Tue Jun 30, 2009 11:47 am |
Quote: | Compiler version: 4.095
Chip: PIC16F886 |
The latest version is 4.093, as far as I know. See the CCS versions page:
http://www.ccsinfo.com/devices.php?page=versioninfo
Quote: | I have this problem where this code compiles, but doesn't work. |
I was able to make it work by putting in numbers for the size of the
2-dimensional array. Here's the output:
Here's the program. This was tested with vs. 4.093.
Code: | #include <16F886.H>
char Greetings[4][16] =
{ "Hello there.",
"Howdy.",
"Hey, you.",
"*mumble mumble*"
int delay = 0;
printf(lcd_buffer);
