Problem with strings.....
PostPosted: Mon Jun 29, 2009 3:05 pm     Reply with quote
Hi All,
I've been using CCS C for a while now, but haven't done much with strings. Now, I have a need and can't seem to get a particular function working correctly.
I have a global string variable containing comma separated data (it happens to be NMEA GPS data). I'd like to call a subroutine, and pass as an argument a comma position. The subroutine would then return all the data between the specified comma position, and the next comma position. I think I can write the subroutine parsing code OK, but I'm having trouble figuring out how to pass data to/from the subroutine. At the moment I'm just trying to get a very basic test case working. Here is what I am trying to do:
char ParseString(int8 NumComma){
   char TempStr[12];
   Switch (NumComma){
      Case '1':
         TempStr[11] = "This is 1";
      Case '2':
         TempStr[11] = "This is 2";
      Case '3':
         TempStr[11] = "This is 3";
   return (TempStr);
and
NMEA_STR[12] = ParseString(1);
fprintf(Console, "%s\n\r", NMEA_STR);
NMEA_STR[12] = ParseString(2);
NMEA_STR[12] = ParseString(3);
Right now I'm just passing the comma position to return different string data, but the fprintf statements are printing garbage characters.
Perhaps there is a better way to do what I'm trying to do?
Thanks,
Dave
PostPosted: Mon Jun 29, 2009 3:14 pm     Reply with quote
You are attempting to return a pointer to a local array.
See this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=38421
PostPosted: Mon Jun 29, 2009 3:46 pm     Reply with quote
Also, C, does not support directly loading strings, except in the initialisation of a variable. Strcpy...
PostPosted: Sun Jul 05, 2009 6:50 pm     Reply with quote
Hi All,
I made life a lot easier by declaring the temporary string, NMEA_STR[] as a global variable. My parsing routine now accepts a message number, and the routine parses the main RxBuffer[] and returns just the data that is requested in the temporary string. This works great, without a lot of (unnecessary) hurdles!
I see a lot of requests for "parsing" routines for NMEA data, and it's actually quite easy. I just loop thru RxBuffer[] counting comma's (the delimiter for NMEA data) until I reach one less than the message number I'm interested in. I then start putting the following characters into my temporary string until the next comma is found. This is then the data I've requested. Lastly, I append '\0' to the last location of the temporary string to terminate it, and I'm done.
Hehe, I wrote the entire routine in my dentists waiting room before having my teeth cleaned!
Dave
