littlet05
ELM to PIC communication VIA RS232 |
Posted: Sun Jun 28, 2009 1:38 pm |
I have been unsuccessful at receiving data from the ELM 327 OBDII chip via RS232. I know the hardware is ok because I have a PIC Basic Pro program written that works ok...
The code that would reset the elm (send it the characters ATZ and the \r character aka 0x0d in hex) in pic basic that is functional reads
RESETELM:
SERout PORTC.6,T9600,["AT Z",13,10]
SERIN2 PORTC.7,84,5000,RESETELM,[SKIP 5,STR elmRead\12]
In CCS C, I have been able to send the ATZ command successfully (my board has the confirmation I/O wired to LED's for the ELM), and the ELM also sends back the reply, which is normally:
I was never able to get the #INT_RDA interrupt to work, or kbhit polling, or using fgetc... it just hangs in the fgetc function.
I'm using MPLAB v8.30 and CCS Compiler 4.3.0.217 and a PICKIT2
Below is me taking the EX_SISR.C file and tailoring it to my application (unsuccessfully).
#include <18F4620.h>
#device adc=10
#fuses H4,NOWDT,NOPROTECT,NOLVP,MCLR
#use delay(clock=40000000)
#use fast_io(d)
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, stream=ELM)
#include <lcd_flex.c>
#define ELMRTS PIN_C2
#define ELMBUSY PIN_C1
#define ELMSLEEP PIN_A3
#define BUZZER PIN_D2
#define SLEEP PIN_D7
#define BUFFER_SIZE 32
BYTE buffer[BUFFER_SIZE];
BYTE next_in = 0;
BYTE next_out = 0;
char msg[4];
void beep(int N, int delay)
for(;N>0;N=N-1)
output_toggle(BUZZER);
delay_us(delay);
#int_rda
void serial_isr() {
int t;
output_high(SLEEP);//attempt to shut off LCD backlight to signal isr entry
buffer[next_in]=fgetc(ELM);
t=next_in;
if(next_in==next_out)
next_in=t; // Buffer full !!
BYTE bgetc() {
BYTE c;
while(!bkbhit) ;
c=buffer[next_out];
return(c);
output_low(SLEEP); //turns on lcd
output_low(ELMSLEEP);//turns on ELM
output_high(ELMRTS);//ELM is allowed to perform tasks
set_tris_a(0x00);
set_tris_b(0x00);
set_tris_c(0x02);//01000010, ELMBUSY is input
set_tris_d(0x00);
set_tris_e(0x00);
enable_interrupts(int_rda);
#if defined(__PCD__)
enable_interrupts(intr_global);
#else
enable_interrupts(global);
output_low(SLEEP);
lcd_init();
lcd_putc(0x0c);//Clear the LCD
lcd_gotoxy(1,1);
printf(lcd_putc,"Hello");
lcd_gotoxy(1,2);
// The program will delay for 10 seconds and then display
// any data that came in during the 10 second delay
do {
delay_ms(2000);
msg[0]='A';msg[1]='T';msg[2]='Z';msg[3]=0x0d; //RESET ELM
fprintf(ELM,"%c",msg[0]);
fprintf(ELM,"%c",msg[1]);
fprintf(ELM,"%c",msg[2]);
fprintf(ELM,"%c",msg[3]);
lcd_gotoxy(1,1);
printf(lcd_putc,"sent");
delay_ms(4000);
while(bkbhit)
printf(lcd_putc,"%c",bgetc() );
} while (TRUE);
Any help or insight would be much appreciated.
Thanks,
JT |
Posted: Sun Jun 28, 2009 2:02 pm |
Quote: | #use fast_io(d)
set_tris_a(0x00);
set_tris_b(0x00);
set_tris_d(0x00);
set_tris_e(0x00); |
Get rid of all this TRIS stuff. Let the compiler set the TRIS for you.
If you use the CCS i/o functions (which you are doing), the compiler
will handle the TRIS for you.
Quote: | #use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, ERRORS, stream=ELM) |
Add ERRORS to the #use rs232() statement. This will prevent the UART
from locking up if you don't read incoming characters often enough. |
littlet05
Posted: Sun Jun 28, 2009 2:36 pm |
I made those two corrections and when I compile I get the warning:
>>> Warning 202 "V2_ELM_SERIAL.c" Line 11(5,8): Variable never used: rs232_errors
I guess I have to catch these errors upon waiting for data on the rcv pin?
And now the LCD won't illuminate, which leads me to believe that output_low(SLEEP) is not toggling.
Shouldn't I assume the TRIS was necessary? |
littlet05
Posted: Sun Jun 28, 2009 2:39 pm |
My mistake, I forgot to comment the #use fast_io(d) upon commenting the tris statements... it seems to spit back some data over rs232.
THANK YOU!
JT |
