how to check an input
PostPosted: Wed Jun 24, 2009 11:38 am     Reply with quote
Hi, I am using PIC16f72 for my project.
I have set port_c as input and port_a digital output (through port_a I operate a Relay), initially port_a is "0xFF" and I want to compare the input of port_c with a desired value.
#include <16f72.h>
#USE DELAY( CLOCK=4000000 ) /* Using a 4 Mhz clock */
#FUSES XT,NOWDT,NOPROTECT,NOPUT
/* Use XT mode, No Watch Dog, No Code Protect, No Power-up Timer */
//PIC_C2=Low_Level
//PIN_C3=High_Level
#byte port_c=7 /* define the location of register port_b */
#byte port_a=5 /* define the location of register port_b */
#define ALL_DIGITAL 7
#define low 0xF7
void pump_on();
void pump_off();
main()
 set_tris_a(0);
 set_tris_c(1);
 setup_adc_ports(ALL_DIGITAL);
 port_a=0;
 //port_c=0;
 output_a(0xFF);
 port_a=0xFF;
   if(port_c==low)
      pump_off();
      pump_on();
void pump_on()
 port_a=0xFF;
void pump_off()
 port_a=0x00;
This is my current code but its not working.
PostPosted: Wed Jun 24, 2009 12:11 pm     Reply with quote
set_tris_c(1);
This function takes a byte, in the form of a bitmask, as the parameter.
A '1' in the bitmask, means to make that bit in the port into an input pin.
A '0' means to make it be an output pin. There are typically 8 i/o pins
in a port.
Therefore, you are only setting Pin C0 as an input. All the rest of the
pins (C1-C7) are set as outputs.
Also, you are mixing direct port i/o operations with the built-in CCS
functions. Sometimes you do this:
output_a(0xFF);
But other times you do this:
port_a=0xFF;
You should choose one method and stick with it.
Also, you have not specified "#use fast_io" mode. This means the
compiler will operate in the default mode, which is called "Standard i/o"
mode. In this mode, the compiler sets the TRIS for you, whenever you
use the built-in i/o functions, such as output_a(), etc. This will conflict
with the set_tris_x() lines in your program. You'll set the TRIS to one
state, and the compiler will over-write that TRIS state when it executes
one of the i/o functions.
You need to use one method or the other.
1. Specify #use fast_io() for the specific ports, and then call the
set_tris_x() functions.
or,
2. Don't specify fast i/o mode. Leave the compiler in standard i/o mode.
Then use only the built-in i/o functions (of which there are many), and
let the compiler handle the TRIS for you automatically.
For a newbie, method #2 is much easier.
bharatwalia
PostPosted: Wed Jun 24, 2009 12:48 pm     Reply with quote
Hi,thanks it worked.
After your suggestion I changed the code according to default settings,
but after sometime the program is hanging up.
Please go through the modified code, so that I can rectify it further.
#include <16f72.h>
//PIC_C2=Low_Level
//PIN_C3=High_Level
#define low 0xF3
void pump_on();
void pump_off();
main()
 //set_tris_a(0x00);
 //set_tris_c(0xFF);
 //port_a=0;
 //port_c=0;
 output_a(0xFF);
 input_c();
//port_a=0xFF;
  if(port_c==low)
  pump_off();
pump_on();
void pump_on()
 port_a=0xFF;
void pump_off()
 port_a=0x00;
PostPosted: Wed Jun 24, 2009 1:17 pm     Reply with quote
You are still misunderstanding how to use the functions.
input_c();
This statement is incorrect. You need to either load a variable with
the result of the input_c() function, or you need to compare the result
to some other expression. Don't use "input_c()" all by itself on a line.
One example of correct usage:
int8 result;
result = input_c();
if(port_c==low)
Here you are still using direct register i/o. If you want to read Port C
continuously inside the loop (and do it in standard i/o mode), then use
the input_c() function. Example:
  if(input_c() == low)
PostPosted: Wed Jun 24, 2009 1:54 pm     Reply with quote
Further rectified it is working but the program is hanging up after sometime.
#include <16f72.h>
//PIC_C2=Low_Level
//PIN_C3=High_Level
#define low 0xF3
void pump_on();
void pump_off();
main()
  if(input_c()==low)
     pump_off();
     pump_on();
void pump_on()
 output_a(0xFF);
void pump_off()
 output_a(0x00);
PostPosted: Wed Jun 24, 2009 1:59 pm     Reply with quote
What is connected to the pins on Port C ?
Post a detailed explanation of the circuits on each pin of Port C.
bharatwalia
PostPosted: Thu Jun 25, 2009 2:23 pm     Reply with quote
Hi, thanks a lot. It worked.
