| 5V PIC & 3.3V GPS |
Posted: Fri Jun 19, 2009 3:34 pm |
Hi All,
Will a PIC 16F628 running at 5V reliably receive data from a GPS module running at 3.3V if the Tx output of the GPS is only guaranteed to swing to 2.85V? The GPS will be connected to the hardware Rx input on the PIC. I looked for this info in the datasheet, but didn't see any threshold level specs. in the UART section.
Chad |
Posted: Fri Jun 19, 2009 5:37 pm |
First look in this table in the 16F628 data sheet, and see the type of input
pin that's used for the Rx pin on the hardware UART. It's called "ST" which
means Schmitt Trigger.
| Quote: | | TABLE 2-1: PIC16F62X PINOUT DESCRIPTION |
Then look in the Electrical Section (in section 17.2) to see the Vih
voltage for a Schmitt Trigger input. It's 0.8 * Vdd. For a Vdd of 5v,
that's 4.0 volts minimum high level voltage required.
So you need a level converter. One way to do this is to use a logic
gate that has TTL input levels, and CMOS output levels. One logic
family that does this is the HCT family. You could use any non-inverting
gate or buffer to do this. For example, a 74HCT125 buffer would work.
Just use one section and connect the \OE pin to ground. (I'm assuming
that you don't want an inversion. If you want to invert the Rx signal, then
a 74HCT04 would work). A single gate version of the 74HCT125 chip
might be available. I didn't check.
There are other solutions in the forum archives. Search for these words:
Set the search options to:
| Quote: | | Search for all terms. |
Posted: Sat Jun 20, 2009 6:56 pm |
PCM,
Thanks for the info, and for the pointer to where in the datasheet this info is found!
It's kludgy, but I think I'll opt for a two transistor buffer/level shifter!
Thanks,
Chad |
